Hello Guest it is October 01, 2026, 10:47:31 AM
Author Topic: Unable to load my NC-File  (Read 21718 times)
Re: Unable to load my NC-File
« Reply #10 on: March 22, 2012, 04:09:41 PM »
Right click on the shortcut and select properties. In the Target box  paste the following
C:\Mach3\Mach3.exe /p MyMill
That is assuming you have Mach3 installed to the default C:\
iIf you dont then you will need to replace the first part with the location you have installed to, take careful not that there are spaces in the above address, one before the /p and another after.
« Reply #11 on: March 22, 2012, 04:28:20 PM »
Thanks, will try that to morrow,- think i will manage alright
Sivtek
« Reply #12 on: March 23, 2012, 06:33:21 AM »
Hi
Fixed the shortcut as you said, and it is OK now.
But a funny thing happend after I had made the shortcut, MyMill took over the load button so I had to rename that button to MyMill. I thought that a new button would appear? But I am happy, thanks again.
Sivtek
