Hello Guest it is November 22, 2026, 02:25:43 PM
Author Topic: moving before all the way down  (Read 14064 times)
« on: March 16, 2012, 02:58:03 PM »
Hi guys Im new to this and had a question about the cnc moving in the y axis before it reached its full depth z of the cut.Im using Mach3. I ve tried to change the constant velocity setting in the general config to exact but it didnt help? If ya need more info just ask please n thanks.
john
Re: moving before all the way down
« Reply #1 on: March 16, 2012, 04:21:42 PM »
I can see when I load the program that the toolpath is just as described Ill try to attach the dxf file.
« Reply #2 on: March 16, 2012, 04:38:28 PM »
Hey John ... Welcome !
You may have a RAMP incorporated into your PLUNGE move.
It is a common approach and is available with the Vectric products.
If you do not have a ramp selected, some pirated SW did similar tricks.
Post the GCode if you will.
Russ
« Reply #3 on: March 16, 2012, 05:13:41 PM »
Code: [Select]
there i think i got it
N5 (File Name = Pinnacle logo vcarve test cut1.1 on Friday, March 16, 2012)
N10 (Default Mill Post)
N15  G91.1
N20 G0  Z1.0000
N25 M3
N30  X1.8562  Y2.5878
N35  Z0.1000
N40 G42
N45 G1  X1.8328  Y2.5794  Z0.0000  F60.00
N50 G0  Z1.0000
N55  X2.2936  Y4.0242
N60  Z0.1000
N65 G42
N70 G1  X2.3017  Y4.0239  Z0.0000
N75  X2.2858  Y4.0363
N80  X2.3093  Y4.0228
N85  X2.3164  Y4.0209
N90  X2.3232  Y4.0184
N95  X2.3293  Y4.0152
N100  X2.3352  Y4.0111
N105  X2.3405  Y4.0064
N110  X2.3454  Y4.0010
N115  X2.3509  Y3.9932
N120  X2.3557  Y3.9846
N125  X2.3596  Y3.9749
N130  X2.3629  Y3.9644
N135  X2.3655  Y3.9529
N140  X2.3673  Y3.9404
N145  X2.3684  Y3.9270
N150  X2.3688  Y3.9126
N155  X2.3684  Y3.8994
N160  X2.3675  Y3.8870
N165  X2.3658  Y3.8756
N170  X2.3634  Y3.8652
N175  X2.3604  Y3.8556
N180  X2.3568  Y3.8470
N185  X2.3526  Y3.8393
N190  X2.3476  Y3.8325
N195  X2.3420  Y3.8265
N200  X2.3363  Y3.8214
N205  X2.3301  Y3.8170
N210  X2.3235  Y3.8134
N215  X2.3166  Y3.8106
N220  X2.3093  Y3.8086
N225  X2.3017  Y3.8074
N230  X2.2938  Y3.8071
N235  X2.2863  Y3.8074
N240  X2.2793  Y3.8085
N245  X2.2727  Y3.8103
N250  X2.2663  Y3.8129
N255  X2.2603  Y3.8161
N260  X2.2548  Y3.8201
N265  X2.2495  Y3.8248
N270  X2.2447  Y3.8302
N275  X2.2391  Y3.8382
N280  X2.2341  Y3.8472
N285  X2.2299  Y3.8568
N290  X2.2265  Y3.8673
N295  X2.2239  Y3.8786
N300  X2.2219  Y3.8907
N305  X2.2209  Y3.9036
N310  X2.2205  Y3.9174
N315  X2.2208  Y3.9308
N320  X2.2219  Y3.9433
N325  X2.2238  Y3.9550
N330  X2.2263  Y3.9660
N335  X2.2296  Y3.9760
N340  X2.2337  Y3.9852
N345  X2.2385  Y3.9937
N350  X2.2439  Y4.0012
N355  X2.2488  Y4.0067
N360  X2.2540  Y4.0112
N365  X2.2597  Y4.0153
N370  X2.2657  Y4.0185
N375  X2.2721  Y4.0210
N380  X2.2789  Y4.0228
N385  X2.2861  Y4.0239
N390  X2.2936  Y4.0242
N395  X2.2858  Y4.0363
N400  X2.2750  Y4.0348
N405  X2.2647  Y4.0324
N410  X2.2548  Y4.0291
N415  X2.2452  Y4.0249
N420  X2.2360  Y4.0198
N425  X2.2273  Y4.0136
N430  X2.2190  Y4.0066
N435  X2.2101  Y3.9975
N440  X2.2026  Y3.9879
N445  X2.1961  Y3.9776
N450  X2.1908  Y3.9667
N455  X2.1867  Y3.9551
N460  X2.1838  Y3.9430
N465  X2.1820  Y3.9301
N470  X2.1815  Y3.9166
N475  X2.1820  Y3.9035
N480  X2.1835  Y3.8910
N485  X2.1860  Y3.8790
N490  X2.1896  Y3.8677
N495  X2.1941  Y3.8571
N500  X2.1998  Y3.8471
N505  X2.2064  Y3.8376
N510  X2.2140  Y3.8288
N515  X2.2223  Y3.8209
N520  X2.2311  Y3.8140
N525  X2.2405  Y3.8082
N530  X2.2503  Y3.8034
N535  X2.2605  Y3.7998
N540  X2.2713  Y3.7971
N545  X2.2825  Y3.7955
N550  X2.2942  Y3.7950
N555  X2.3058  Y3.7955
N560  X2.3169  Y3.7971
N565  X2.3276  Y3.7999
N570  X2.3379  Y3.8037
N575  X2.3477  Y3.8085
N580  X2.3571  Y3.8146
N585  X2.3661  Y3.8216
N590  X2.3746  Y3.8297
N595  X2.3824  Y3.8387
N600  X2.3892  Y3.8482
N605  X2.3949  Y3.8584
N610  X2.3995  Y3.8689
N615  X2.4032  Y3.8802
N620  X2.4058  Y3.8919
N625  X2.4073  Y3.9043
N630  X2.4079  Y3.9172
N635  X2.4073  Y3.9297
N640  X2.4058  Y3.9417
N645  X2.4032  Y3.9532
N650  X2.3997  Y3.9640
N655  X2.3950  Y3.9745
N660  X2.3893  Y3.9844
N665  X2.3826  Y3.9937
N670  X2.3748  Y4.0025
N675  X2.3664  Y4.0105
N680  X2.3576  Y4.0174
N685  X2.3484  Y4.0234
N690  X2.3389  Y4.0282
N695  X2.3289  Y4.0319
N700  X2.3186  Y4.0346
N705  X2.3079  Y4.0362
N710  X2.2968  Y4.0367
N715 G0  Z1.0000
N720  X2.1314
N725  Z0.0000
N730 G1  X2.1250
N735  X2.1247  Y4.0327
N740  X2.1240  Y4.0294
N745  X2.1233  Y4.0268
N750  X2.1222  Y4.0250
N755  X2.1197  Y4.0228
N760  X2.1167  Y4.0220
N765  X2.1147  Y4.0222
N770  X2.1119  Y4.0229
N775  X2.1083  Y4.0240
N780  X2.1039  Y4.0256
N785  X2.0950  Y4.0288
N790  X2.0872  Y4.0314
N795  X2.0804  Y4.0333
N800  X2.0747  Y4.0346
N805  X2.0637  Y4.0362
N810  X2.0517  Y4.0367
N815  X2.0350  Y4.0357
N820  X2.0194  Y4.0330
N825  X2.0050  Y4.0284
N830  X1.9917  Y4.0219
N835  X1.9773  Y4.0119
N840  X1.9647  Y4.0001
N845  X1.9535  Y3.9863
N850  X1.9440  Y3.9708
N855  X1.9376  Y3.9566
N860  X1.9330  Y3.9421
N865  X1.9303  Y3.9274
N870  X1.9294  Y3.9123
N875  X1.9298  Y3.9018
N880  X1.9310  Y3.8918
N885  X1.9330  Y3.8820
N890  X1.9359  Y3.8726
N895  X1.9395  Y3.8635
N900  X1.9440  Y3.8546
N905  X1.9493  Y3.8461
N910  X1.9554  Y3.8379
N915  X1.9645  Y3.8278
N920  X1.9748  Y3.8192
N925  X1.9861  Y3.8117
N930  X1.9982  Y3.8057
N935  X2.0114  Y3.8010
N940  X2.0257  Y3.7976
N945  X2.0409  Y3.7956
N950  X2.0572  Y3.7950
N955  X2.0795  Y3.7961
N960  X2.0996  Y3.7999
N965  X2.1092  Y3.8027
N970  X2.1189  Y3.8063
N975  X2.1286  Y3.8105
N980  X2.1383  Y3.8154
N985  Y3.8862
N990  X2.1385  Y3.8947
N995  X2.1392  Y3.9016
N1000  X2.1402  Y3.9072
N1005  X2.1417  Y3.9111
N1010  X2.1447  Y3.9149
N1015  X2.1488  Y3.9177
N1020  X2.1539  Y3.9194
N1025  X2.1599  Y3.9199
N1030  X2.1642
N1035  Y3.9264
N1040  X2.0747
N1045  Y3.9199
N1050  X2.0812  Y3.9197
N1055  X2.0866  Y3.9192
N1060  X2.0910  Y3.9183
N1065  X2.0943  Y3.9171
N1070  X2.0991  Y3.9137
N1075  X2.1024  Y3.9089
N1080  X2.1036  Y3.9055
N1085  X2.1044  Y3.9005
N1090  X2.1049  Y3.8942
N1095  X2.1051  Y3.8862
N1100  Y3.8194
N1105  X2.0938  Y3.8137
N1110  X2.0821  Y3.8098
N1115  X2.0699  Y3.8073
N1120  X2.0573  Y3.8066
N1125  X2.0466  Y3.8073
N1130  X2.0358  Y3.8097
N1135  X2.0253  Y3.8137
N1140  X2.0148  Y3.8193
N1145  X2.0049  Y3.8265
N1150  X1.9961  Y3.8356
N1155  X1.9883  Y3.8464
N1160  X1.9814  Y3.8592
N1165  X1.9758  Y3.8733
N1170  X1.9718  Y3.8880
N1175  X1.9694  Y3.9034
N1180  X1.9686  Y3.9196
N1185  X1.9698  Y3.9392
N1190  X1.9734  Y3.9574
N1195  X1.9794  Y3.9744
N1200  X1.9878  Y3.9898
N1205  X1.9938  Y3.9980
N1210  X2.0007  Y4.0051
N1215  X2.0080  Y4.0111
N1220  X2.0161  Y4.0160
N1225  X2.0248  Y4.0199
N1230  X2.0342  Y4.0225
N1235  X2.0443  Y4.0242
N1240  X2.0550  Y4.0248
N1245  X2.0704  Y4.0235
N1250  X2.0844  Y4.0198
N1255  X2.0969  Y4.0136
N1260  X2.1079  Y4.0049
N1265  X2.1148  Y3.9971
N1270  X2.1209  Y3.9876
N1275  X2.1265  Y3.9765
N1280  X2.1314  Y3.9637
N1285  X2.1374
N1290 G40
N1295  X2.1314  Y4.0367
N1300 G0  Z1.0000
N1305  X2.7060  Y4.0188
N1310  Z0.1000
N1315 G42
N1320 G1  X2.7570  Z0.0000
N1325  X2.7654  Y4.0186
N1330  X2.7726  Y4.0180
N1335  X2.7787  Y4.0169
N1340  X2.7836  Y4.0154
N1345  X2.7915  Y4.0109
N1350  X2.7981  Y4.0043
N1355  X2.8010  Y4.0001
N1360  X2.8036  Y3.9946
N1365  X2.8061  Y3.9881
N1370  X2.8084  Y3.9806
N1375  X2.8144
N1380  X2.8122  Y4.0314
N1385  X2.6402
N1390  Y4.0251
N1395  X2.6483
N1400  X2.6565  Y4.0240
N1405  X2.6641  Y4.0210
N1410  X2.6685  Y4.0176
N1415  X2.6710  Y4.0137
N1420  X2.6720  Y4.0101
N1425  X2.6727  Y4.0051
N1430  X2.6731  Y3.9985
N1435  X2.6732  Y3.9905
N1440  Y3.8412
N1445  X2.6730  Y3.8317
N1450  X2.6722  Y3.8242
N1455  X2.6709  Y3.8186
N1460  X2.6692  Y3.8149
N1465  X2.6655  Y3.8113
N1470  X2.6607  Y3.8086
N1475  X2.6550  Y3.8071
N1480  X2.6483  Y3.8066
N1485  X2.6402
N1490  Y3.8003
N1495  X2.7394
N1500  Y3.8066
N1505  X2.7310
N1510  X2.7230  Y3.8075
N1515  X2.7153  Y3.8106
N1520  X2.7109  Y3.8139
N1525  X2.7082  Y3.8180
N1530  X2.7072  Y3.8215
N1535  X2.7065  Y3.8266
N1540  X2.7061  Y3.8331
N1545  X2.7060  Y3.8412
N1550  Y3.9138
N1555  X2.7480
N1560  X2.7535  Y3.9135
N1565  X2.7583  Y3.9129
N1570  X2.7622  Y3.9119
N1575  X2.7655  Y3.9106
N1580  X2.7708  Y3.9066
N1585  X2.7748  Y3.9012
N1590  X2.7763  Y3.8976
N1595  X2.7773  Y3.8930
N1600  X2.7780  Y3.8877
N1605  X2.7783  Y3.8814
N1610  X2.7846
N1615  Y3.9597
N1620  X2.7783
N1625  X2.7769  Y3.9509
N1630  X2.7750  Y3.9438
N1635  X2.7724  Y3.9383
N1640  X2.7693  Y3.9343
N1645  X2.7655  Y3.9316
N1650  X2.7606  Y3.9295
N1655  X2.7549  Y3.9284
N1660  X2.7480  Y3.9279
N1665  X2.7060
N1670  Y4.0188
N1675 G0  Z1.0000
N1680  X2.6215  Y3.8642
N1685  Z0.0000
N1690 G1  X2.6170  Y3.8542
N1695  X2.6126  Y3.8456
N1700  X2.6081  Y3.8384
N1705  X2.6037  Y3.8327
N1710  X2.5991  Y3.8281
N1715  X2.5944  Y3.8243
N1720  X2.5893  Y3.8212
N1725  X2.5841  Y3.8188
N1730  X2.5777  Y3.8171
N1735  X2.5694  Y3.8159
N1740  X2.5590  Y3.8151
N1745  X2.5468  Y3.8149
N1750  X2.5298
N1755  X2.5198  Y3.8150
N1760  X2.5122  Y3.8153
N1765  X2.5066  Y3.8159
N1770  X2.5033  Y3.8166
N1775  X2.4996  Y3.8187
N1780  X2.4970  Y3.8219
N1785  X2.4959  Y3.8251
N1790  X2.4950  Y3.8294
N1795  X2.4945  Y3.8348
N1800  X2.4943  Y3.8413
N1805  Y3.9865
N1810  X2.4945  Y3.9959
N1815  X2.4950  Y4.0034
N1820  X2.4959  Y4.0090
N1825  X2.4970  Y4.0126
N1830  X2.5009  Y4.0176
N1835  X2.5072  Y4.0217
N1840  X2.5115  Y4.0232
N1845  X2.5173  Y4.0243
N1850  X2.5244  Y4.0250
N1855  X2.5329  Y4.0251
N1860  Y4.0314
N1865  X2.4283
N1870  Y4.0251
N1875  X2.4369
N1880  X2.4431  Y4.0247
N1885  X2.4484  Y4.0232
N1890  X2.4530  Y4.0208
N1895  X2.4568  Y4.0176
N1900  X2.4589  Y4.0139
N1905  X2.4604  Y4.0080
N1910  X2.4612  Y4.0003
N1915  X2.4616  Y3.9905
N1920  Y3.8413
N1925  X2.4613  Y3.8323
N1930  X2.4607  Y3.8251
N1935  X2.4595  Y3.8197
N1940  X2.4579  Y3.8161
N1945  X2.4543  Y3.8119
N1950  X2.4495  Y3.8089
N1955  X2.4438  Y3.8072
N1960  X2.4369  Y3.8066
N1965  X2.4283
N1970  Y3.8003
N1975  X2.6073
N1980  X2.6270  Y3.8629
N1985 G40
N1990  X2.6215  Y3.8642
N1995 G0  Z1.0000
N2000  X3.2396  Y3.8153
N2005  Z0.1000
N2010 G42
N2015 G1  X3.2341  Y3.8159  Z0.0000
N2020  X3.2218  Y3.9865
N2025  X3.2220  Y3.9959
N2030  X3.2225  Y4.0034
« Reply #4 on: March 16, 2012, 08:46:08 PM »
i found a g code commenter program it didnt help me maybe itll help you
N20 G00 M03 S1200 ( G00:Rapid positioning M03:Spindle On S:Spindle Speed:1200 )
N15  G91.1 ( G91:Incremental programming )
N20 G0  Z1.0000 ( G00:Rapid positioning Z:1.0000 )
N25 M3 ( M03:Spindle On )
N30  X1.8562  Y2.5878 ( X:1.8562   Y:2.5878 )
N35  Z0.1000 ( Z:0.1000 )
N40 G42 ( G42:Tool radius compensation right )
N45 G1  X1.8328  Y2.5794  Z0.0000  F60.00 ( G01:Linear interpolation X:1.8328   Y:2.5794   Z:0.0000   F:Feedrate:60.00 )
N50 G0  Z1.0000 ( G00:Rapid positioning Z:1.0000 )
N55  X2.2936  Y4.0242 ( X:2.2936   Y:4.0242 )
N60  Z0.1000 ( Z:0.1000 )
N65 G42 ( G42:Tool radius compensation right )
N70 G1  X2.3017  Y4.0239  Z0.0000 ( G01:Linear interpolation X:2.3017   Y:4.0239   Z:0.0000 )
N75  X2.2858  Y4.0363 ( X:2.2858   Y:4.0363 )
N80  X2.3093  Y4.0228 ( X:2.3093   Y:4.0228 )
N85  X2.3164  Y4.0209 ( X:2.3164   Y:4.0209 )
N90  X2.3232  Y4.0184 ( X:2.3232   Y:4.0184 )
N95  X2.3293  Y4.0152 ( X:2.3293   Y:4.0152 )
N100  X2.3352  Y4.0111 ( X:2.3352   Y:4.0111 )
N105  X2.3405  Y4.0064 ( X:2.3405   Y:4.0064 )
N110  X2.3454  Y4.0010 ( X:2.3454   Y:4.0010 )
N115  X2.3509  Y3.9932 ( X:2.3509   Y:3.9932 )
N120  X2.3557  Y3.9846 ( X:2.3557   Y:3.9846 )
N125  X2.3596  Y3.9749 ( X:2.3596   Y:3.9749 )
N130  X2.3629  Y3.9644 ( X:2.3629   Y:3.9644 )
N135  X2.3655  Y3.9529 ( X:2.3655   Y:3.9529 )
N140  X2.3673  Y3.9404 ( X:2.3673   Y:3.9404 )
N145  X2.3684  Y3.9270 ( X:2.3684   Y:3.9270 )
N150  X2.3688  Y3.9126 ( X:2.3688   Y:3.9126 )
N155  X2.3684  Y3.8994 ( X:2.3684   Y:3.8994 )
N160  X2.3675  Y3.8870 ( X:2.3675   Y:3.8870 )
N165  X2.3658  Y3.8756 ( X:2.3658   Y:3.8756 )
N170  X2.3634  Y3.8652 ( X:2.3634   Y:3.8652 )
N175  X2.3604  Y3.8556 ( X:2.3604   Y:3.8556 )
N180  X2.3568  Y3.8470 ( X:2.3568   Y:3.8470 )
N185  X2.3526  Y3.8393 ( X:2.3526   Y:3.8393 )
N190  X2.3476  Y3.8325 ( X:2.3476   Y:3.8325 )
N195  X2.3420  Y3.8265 ( X:2.3420   Y:3.8265 )
N200  X2.3363  Y3.8214 ( X:2.3363   Y:3.8214 )
N205  X2.3301  Y3.8170 ( X:2.3301   Y:3.8170 )
N210  X2.3235  Y3.8134 ( X:2.3235   Y:3.8134 )
N215  X2.3166  Y3.8106 ( X:2.3166   Y:3.8106 )
N220  X2.3093  Y3.8086 ( X:2.3093   Y:3.8086 )
N225  X2.3017  Y3.8074 ( X:2.3017   Y:3.8074 )
N230  X2.2938  Y3.8071 ( X:2.2938   Y:3.8071 )
N235  X2.2863  Y3.8074 ( X:2.2863   Y:3.8074 )
N240  X2.2793  Y3.8085 ( X:2.2793   Y:3.8085 )
N245  X2.2727  Y3.8103 ( X:2.2727   Y:3.8103 )
N250  X2.2663  Y3.8129 ( X:2.2663   Y:3.8129 )
N255  X2.2603  Y3.8161 ( X:2.2603   Y:3.8161 )
N260  X2.2548  Y3.8201 ( X:2.2548   Y:3.8201 )
N265  X2.2495  Y3.8248 ( X:2.2495   Y:3.8248 )
N270  X2.2447  Y3.8302 ( X:2.2447   Y:3.8302 )
N275  X2.2391  Y3.8382 ( X:2.2391   Y:3.8382 )
N280  X2.2341  Y3.8472 ( X:2.2341   Y:3.8472 )
N285  X2.2299  Y3.8568 ( X:2.2299   Y:3.8568 )
N290  X2.2265  Y3.8673 ( X:2.2265   Y:3.8673 )
N295  X2.2239  Y3.8786 ( X:2.2239   Y:3.8786 )
N300  X2.2219  Y3.8907 ( X:2.2219   Y:3.8907 )
N305  X2.2209  Y3.9036 ( X:2.2209   Y:3.9036 )
N310  X2.2205  Y3.9174 ( X:2.2205   Y:3.9174 )
N315  X2.2208  Y3.9308 ( X:2.2208   Y:3.9308 )
N320  X2.2219  Y3.9433 ( X:2.2219   Y:3.9433 )
N325  X2.2238  Y3.9550 ( X:2.2238   Y:3.9550 )
N330  X2.2263  Y3.9660 ( X:2.2263   Y:3.9660 )
N335  X2.2296  Y3.9760 ( X:2.2296   Y:3.9760 )
N340  X2.2337  Y3.9852 ( X:2.2337   Y:3.9852 )
N345  X2.2385  Y3.9937 ( X:2.2385   Y:3.9937 )
N350  X2.2439  Y4.0012 ( X:2.2439   Y:4.0012 )
N355  X2.2488  Y4.0067 ( X:2.2488   Y:4.0067 )
N360  X2.2540  Y4.0112 ( X:2.2540   Y:4.0112 )
N365  X2.2597  Y4.0153 ( X:2.2597   Y:4.0153 )
N370  X2.2657  Y4.0185 ( X:2.2657   Y:4.0185 )
N375  X2.2721  Y4.0210 ( X:2.2721   Y:4.0210 )
N380  X2.2789  Y4.0228 ( X:2.2789   Y:4.0228 )
N385  X2.2861  Y4.0239 ( X:2.2861   Y:4.0239 )
N390  X2.2936  Y4.0242 ( X:2.2936   Y:4.0242 )
N395  X2.2858  Y4.0363 ( X:2.2858   Y:4.0363 )
N400  X2.2750  Y4.0348 ( X:2.2750   Y:4.0348 )
N405  X2.2647  Y4.0324 ( X:2.2647   Y:4.0324 )
N410  X2.2548  Y4.0291 ( X:2.2548   Y:4.0291 )
N415  X2.2452  Y4.0249 ( X:2.2452   Y:4.0249 )
N420  X2.2360  Y4.0198 ( X:2.2360   Y:4.0198 )
N425  X2.2273  Y4.0136 ( X:2.2273   Y:4.0136 )
N430  X2.2190  Y4.0066 ( X:2.2190   Y:4.0066 )
N435  X2.2101  Y3.9975 ( X:2.2101   Y:3.9975 )
N440  X2.2026  Y3.9879 ( X:2.2026   Y:3.9879 )
N445  X2.1961  Y3.9776 ( X:2.1961   Y:3.9776 )
N450  X2.1908  Y3.9667 ( X:2.1908   Y:3.9667 )
N455  X2.1867  Y3.9551 ( X:2.1867   Y:3.9551 )
N460  X2.1838  Y3.9430 ( X:2.1838   Y:3.9430 )
N465  X2.1820  Y3.9301 ( X:2.1820   Y:3.9301 )
N470  X2.1815  Y3.9166 ( X:2.1815   Y:3.9166 )
N475  X2.1820  Y3.9035 ( X:2.1820   Y:3.9035 )
N480  X2.1835  Y3.8910 ( X:2.1835   Y:3.8910 )
N485  X2.1860  Y3.8790 ( X:2.1860   Y:3.8790 )
N490  X2.1896  Y3.8677 ( X:2.1896   Y:3.8677 )
N495  X2.1941  Y3.8571 ( X:2.1941   Y:3.8571 )
N500  X2.1998  Y3.8471 ( X:2.1998   Y:3.8471 )
N505  X2.2064  Y3.8376 ( X:2.2064   Y:3.8376 )
N510  X2.2140  Y3.8288 ( X:2.2140   Y:3.8288 )
N515  X2.2223  Y3.8209 ( X:2.2223   Y:3.8209 )
N520  X2.2311  Y3.8140 ( X:2.2311   Y:3.8140 )
N525  X2.2405  Y3.8082 ( X:2.2405   Y:3.8082 )
N530  X2.2503  Y3.8034 ( X:2.2503   Y:3.8034 )
N535  X2.2605  Y3.7998 ( X:2.2605   Y:3.7998 )
N540  X2.2713  Y3.7971 ( X:2.2713   Y:3.7971 )
N545  X2.2825  Y3.7955 ( X:2.2825   Y:3.7955 )
N550  X2.2942  Y3.7950 ( X:2.2942   Y:3.7950 )
N555  X2.3058  Y3.7955 ( X:2.3058   Y:3.7955 )
N560  X2.3169  Y3.7971 ( X:2.3169   Y:3.7971 )
N565  X2.3276  Y3.7999 ( X:2.3276   Y:3.7999 )
N570  X2.3379  Y3.8037 ( X:2.3379   Y:3.8037 )
N575  X2.3477  Y3.8085 ( X:2.3477   Y:3.8085 )
N580  X2.3571  Y3.8146 ( X:2.3571   Y:3.8146 )
N585  X2.3661  Y3.8216 ( X:2.3661   Y:3.8216 )
N590  X2.3746  Y3.8297 ( X:2.3746   Y:3.8297 )
N595  X2.3824  Y3.8387 ( X:2.3824   Y:3.8387 )
N600  X2.3892  Y3.8482 ( X:2.3892   Y:3.8482 )
N605  X2.3949  Y3.8584 ( X:2.3949   Y:3.8584 )
N610  X2.3995  Y3.8689 ( X:2.3995   Y:3.8689 )
N615  X2.4032  Y3.8802 ( X:2.4032   Y:3.8802 )
N620  X2.4058  Y3.8919 ( X:2.4058   Y:3.8919 )
N625  X2.4073  Y3.9043 ( X:2.4073   Y:3.9043 )
N630  X2.4079  Y3.9172 ( X:2.4079   Y:3.9172 )
N635  X2.4073  Y3.9297 ( X:2.4073   Y:3.9297 )
N640  X2.4058  Y3.9417 ( X:2.4058   Y:3.9417 )
N645  X2.4032  Y3.9532 ( X:2.4032   Y:3.9532 )
N650  X2.3997  Y3.9640 ( X:2.3997   Y:3.9640 )
N655  X2.3950  Y3.9745 ( X:2.3950   Y:3.9745 )
N660  X2.3893  Y3.9844 ( X:2.3893   Y:3.9844 )
N665  X2.3826  Y3.9937 ( X:2.3826   Y:3.9937 )
N670  X2.3748  Y4.0025 ( X:2.3748   Y:4.0025 )
N675  X2.3664  Y4.0105 ( X:2.3664   Y:4.0105 )
N680  X2.3576  Y4.0174 ( X:2.3576   Y:4.0174 )
N685  X2.3484  Y4.0234 ( X:2.3484   Y:4.0234 )
N690  X2.3389  Y4.0282 ( X:2.3389   Y:4.0282 )
N695  X2.3289  Y4.0319 ( X:2.3289   Y:4.0319 )
N700  X2.3186  Y4.0346 ( X:2.3186   Y:4.0346 )
N705  X2.3079  Y4.0362 ( X:2.3079   Y:4.0362 )
N710  X2.2968  Y4.0367 ( X:2.2968   Y:4.0367 )
N715 G0  Z1.0000 ( G00:Rapid positioning Z:1.0000 )
N720  X2.1314 ( X:2.1314 )
N725  Z0.0000 ( Z:0.0000 )
N730 G1  X2.1250 ( G01:Linear interpolation X:2.1250 )
N735  X2.1247  Y4.0327 ( X:2.1247   Y:4.0327 )
N740  X2.1240  Y4.0294 ( X:2.1240   Y:4.0294 )
N745  X2.1233  Y4.0268 ( X:2.1233   Y:4.0268 )
N750  X2.1222  Y4.0250 ( X:2.1222   Y:4.0250 )
N755  X2.1197  Y4.0228 ( X:2.1197   Y:4.0228 )
N760  X2.1167  Y4.0220 ( X:2.1167   Y:4.0220 )
N765  X2.1147  Y4.0222 ( X:2.1147   Y:4.0222 )
N770  X2.1119  Y4.0229 ( X:2.1119   Y:4.0229 )
N775  X2.1083  Y4.0240 ( X:2.1083   Y:4.0240 )
N780  X2.1039  Y4.0256 ( X:2.1039   Y:4.0256 )
N785  X2.0950  Y4.0288 ( X:2.0950   Y:4.0288 )
N790  X2.0872  Y4.0314 ( X:2.0872   Y:4.0314 )
N795  X2.0804  Y4.0333 ( X:2.0804   Y:4.0333 )
N800  X2.0747  Y4.0346 ( X:2.0747   Y:4.0346 )
N805  X2.0637  Y4.0362 ( X:2.0637   Y:4.0362 )
N810  X2.0517  Y4.0367 ( X:2.0517   Y:4.0367 )
N815  X2.0350  Y4.0357 ( X:2.0350   Y:4.0357 )
N820  X2.0194  Y4.0330 ( X:2.0194   Y:4.0330 )
N825  X2.0050  Y4.0284 ( X:2.0050   Y:4.0284 )
N830  X1.9917  Y4.0219 ( X:1.9917   Y:4.0219 )
N835  X1.9773  Y4.0119 ( X:1.9773   Y:4.0119 )
N840  X1.9647  Y4.0001 ( X:1.9647   Y:4.0001 )
N845  X1.9535  Y3.9863 ( X:1.9535   Y:3.9863 )
N850  X1.9440  Y3.9708 ( X:1.9440   Y:3.9708 )
N855  X1.9376  Y3.9566 ( X:1.9376   Y:3.9566 )
N860  X1.9330  Y3.9421 ( X:1.9330   Y:3.9421 )
N865  X1.9303  Y3.9274 ( X:1.9303   Y:3.9274 )
N870  X1.9294  Y3.9123 ( X:1.9294   Y:3.9123 )
N875  X1.9298  Y3.9018 ( X:1.9298   Y:3.9018 )
N880  X1.9310  Y3.8918 ( X:1.9310   Y:3.8918 )
N885  X1.9330  Y3.8820 ( X:1.9330   Y:3.8820 )
N890  X1.9359  Y3.8726 ( X:1.9359   Y:3.8726 )
N895  X1.9395  Y3.8635 ( X:1.9395   Y:3.8635 )
N900  X1.9440  Y3.8546 ( X:1.9440   Y:3.8546 )
N905  X1.9493  Y3.8461 ( X:1.9493   Y:3.8461 )
N910  X1.9554  Y3.8379 ( X:1.9554   Y:3.8379 )
N915  X1.9645  Y3.8278 ( X:1.9645   Y:3.8278 )
N920  X1.9748  Y3.8192 ( X:1.9748   Y:3.8192 )
N925  X1.9861  Y3.8117 ( X:1.9861   Y:3.8117 )
N930  X1.9982  Y3.8057 ( X:1.9982   Y:3.8057 )
N935  X2.0114  Y3.8010 ( X:2.0114   Y:3.8010 )
N940  X2.0257  Y3.7976 ( X:2.0257   Y:3.7976 )
N945  X2.0409  Y3.7956 ( X:2.0409   Y:3.7956 )
N950  X2.0572  Y3.7950 ( X:2.0572   Y:3.7950 )
N955  X2.0795  Y3.7961 ( X:2.0795   Y:3.7961 )
N960  X2.0996  Y3.7999 ( X:2.0996   Y:3.7999 )
N965  X2.1092  Y3.8027 ( X:2.1092   Y:3.8027 )
N970  X2.1189  Y3.8063 ( X:2.1189   Y:3.8063 )
N975  X2.1286  Y3.8105 ( X:2.1286   Y:3.8105 )
N980  X2.1383  Y3.8154 ( X:2.1383   Y:3.8154 )
N985  Y3.8862 ( Y:3.8862 )
N990  X2.1385  Y3.8947 ( X:2.1385   Y:3.8947 )
N995  X2.1392  Y3.9016 ( X:2.1392   Y:3.9016 )
N1000  X2.1402  Y3.9072 ( X:2.1402   Y:3.9072 )
N1005  X2.1417  Y3.9111 ( X:2.1417   Y:3.9111 )
N1010  X2.1447  Y3.9149 ( X:2.1447   Y:3.9149 )
N1015  X2.1488  Y3.9177 ( X:2.1488   Y:3.9177 )
N1020  X2.1539  Y3.9194 ( X:2.1539   Y:3.9194 )
N1025  X2.1599  Y3.9199 ( X:2.1599   Y:3.9199 )
N1030  X2.1642 ( X:2.1642 )
N1035  Y3.9264 ( Y:3.9264 )
N1040  X2.0747 ( X:2.0747 )
N1045  Y3.9199 ( Y:3.9199 )
N1050  X2.0812  Y3.9197 ( X:2.0812   Y:3.9197 )
N1055  X2.0866  Y3.9192 ( X:2.0866   Y:3.9192 )
N1060  X2.0910  Y3.9183 ( X:2.0910   Y:3.9183 )
N1065  X2.0943  Y3.9171 ( X:2.0943   Y:3.9171 )
N1070  X2.0991  Y3.9137 ( X:2.0991   Y:3.9137 )
N1075  X2.1024  Y3.9089 ( X:2.1024   Y:3.9089 )
N1080  X2.1036  Y3.9055 ( X:2.1036   Y:3.9055 )
N1085  X2.1044  Y3.9005 ( X:2.1044   Y:3.9005 )
N1090  X2.1049  Y3.8942 ( X:2.1049   Y:3.8942 )
N1095  X2.1051  Y3.8862 ( X:2.1051   Y:3.8862 )
N1100  Y3.8194 ( Y:3.8194 )
N1105  X2.0938  Y3.8137 ( X:2.0938   Y:3.8137 )
N1110  X2.0821  Y3.8098 ( X:2.0821   Y:3.8098 )
N1115  X2.0699  Y3.8073 ( X:2.0699   Y:3.8073 )
N1120  X2.0573  Y3.8066 ( X:2.0573   Y:3.8066 )
N1125  X2.0466  Y3.8073 ( X:2.0466   Y:3.8073 )
N1130  X2.0358  Y3.8097 ( X:2.0358   Y:3.8097 )
N1135  X2.0253  Y3.8137 ( X:2.0253   Y:3.8137 )
N1140  X2.0148  Y3.8193 ( X:2.0148   Y:3.8193 )
N1145  X2.0049  Y3.8265 ( X:2.0049   Y:3.8265 )
N1150  X1.9961  Y3.8356 ( X:1.9961   Y:3.8356 )
N1155  X1.9883  Y3.8464 ( X:1.9883   Y:3.8464 )
N1160  X1.9814  Y3.8592 ( X:1.9814   Y:3.8592 )
N1165  X1.9758  Y3.8733 ( X:1.9758   Y:3.8733 )
N1170  X1.9718  Y3.8880 ( X:1.9718   Y:3.8880 )
N1175  X1.9694  Y3.9034 ( X:1.9694   Y:3.9034 )
N1180  X1.9686  Y3.9196 ( X:1.9686   Y:3.9196 )
N1185  X1.9698  Y3.9392 ( X:1.9698   Y:3.9392 )
N1190  X1.9734  Y3.9574 ( X:1.9734   Y:3.9574 )
N1195  X1.9794  Y3.9744 ( X:1.9794   Y:3.9744 )
N1200  X1.9878  Y3.9898 ( X:1.9878   Y:3.9898 )
N1205  X1.9938  Y3.9980 ( X:1.9938   Y:3.9980 )
N1210  X2.0007  Y4.0051 ( X:2.0007   Y:4.0051 )
N1215  X2.0080  Y4.0111 ( X:2.0080   Y:4.0111 )
N1220  X2.0161  Y4.0160 ( X:2.0161   Y:4.0160 )
N1225  X2.0248  Y4.0199 ( X:2.0248   Y:4.0199 )
N1230  X2.0342  Y4.0225 ( X:2.0342   Y:4.0225 )
N1235  X2.0443  Y4.0242 ( X:2.0443   Y:4.0242 )
N1240  X2.0550  Y4.0248 ( X:2.0550   Y:4.0248 )
N1245  X2.0704  Y4.0235 ( X:2.0704   Y:4.0235 )
N1250  X2.0844  Y4.0198 ( X:2.0844   Y:4.0198 )
N1255  X2.0969  Y4.0136 ( X:2.0969   Y:4.0136 )
N1260  X2.1079  Y4.0049 ( X:2.1079   Y:4.0049 )
N1265  X2.1148  Y3.9971 ( X:2.1148   Y:3.9971 )
N1270  X2.1209  Y3.9876 ( X:2.1209   Y:3.9876 )
N1275  X2.1265  Y3.9765 ( X:2.1265   Y:3.9765 )
N1280  X2.1314  Y3.9637 ( X:2.1314   Y:3.9637 )
N1285  X2.1374 ( X:2.1374 )
N1290 G40 ( G40:Tool radius comp off )
N1295  X2.1314  Y4.0367 ( X:2.1314   Y:4.0367 )
N1300 G0  Z1.0000 ( G00:Rapid positioning Z:1.0000 )
N1305  X2.7060  Y4.0188 ( X:2.7060   Y:4.0188 )
N1310  Z0.1000 ( Z:0.1000 )
N1315 G42 ( G42:Tool radius compensation right )
N1320 G1  X2.7570  Z0.0000 ( G01:Linear interpolation X:2.7570   Z:0.0000 )
N1325  X2.7654  Y4.0186 ( X:2.7654   Y:4.0186 )
N1330  X2.7726  Y4.0180 ( X:2.7726   Y:4.0180 )
N1335  X2.7787  Y4.0169 ( X:2.7787   Y:4.0169 )
N1340  X2.7836  Y4.0154 ( X:2.7836   Y:4.0154 )
N1345  X2.7915  Y4.0109 ( X:2.7915   Y:4.0109 )
N1350  X2.7981  Y4.0043 ( X:2.7981   Y:4.0043 )
N1355  X2.8010  Y4.0001 ( X:2.8010   Y:4.0001 )
N1360  X2.8036  Y3.9946 ( X:2.8036   Y:3.9946 )
N1365  X2.8061  Y3.9881 ( X:2.8061   Y:3.9881 )
N1370  X2.8084  Y3.9806 ( X:2.8084   Y:3.9806 )
N1375  X2.8144 ( X:2.8144 )
N1380  X2.8122  Y4.0314 ( X:2.8122   Y:4.0314 )
N1385  X2.6402 ( X:2.6402 )
N1390  Y4.0251 ( Y:4.0251 )
N1395  X2.6483 ( X:2.6483 )
N1400  X2.6565  Y4.0240 ( X:2.6565   Y:4.0240 )
N1405  X2.6641  Y4.0210 ( X:2.6641   Y:4.0210 )
N1410  X2.6685  Y4.0176 ( X:2.6685   Y:4.0176 )
N1415  X2.6710  Y4.0137 ( X:2.6710   Y:4.0137 )
N1420  X2.6720  Y4.0101 ( X:2.6720   Y:4.0101 )
N1425  X2.6727  Y4.0051 ( X:2.6727   Y:4.0051 )
N1430  X2.6731  Y3.9985 ( X:2.6731   Y:3.9985 )
N1435  X2.6732  Y3.9905 ( X:2.6732   Y:3.9905 )
N1440  Y3.8412 ( Y:3.8412 )
N1445  X2.6730  Y3.8317 ( X:2.6730   Y:3.8317 )
N1450  X2.6722  Y3.8242 ( X:2.6722   Y:3.8242 )
N1455  X2.6709  Y3.8186 ( X:2.6709   Y:3.8186 )
N1460  X2.6692  Y3.8149 ( X:2.6692   Y:3.8149 )
N1465  X2.6655  Y3.8113 ( X:2.6655   Y:3.8113 )
N1470  X2.6607  Y3.8086 ( X:2.6607   Y:3.8086 )
N1475  X2.6550  Y3.8071 ( X:2.6550   Y:3.8071 )
N1480  X2.6483  Y3.8066 ( X:2.6483   Y:3.8066 )
N1485  X2.6402 ( X:2.6402 )
N1490  Y3.8003 ( Y:3.8003 )
N1495  X2.7394 ( X:2.7394 )
N1500  Y3.8066 ( Y:3.8066 )
N1505  X2.7310 ( X:2.7310 )
N1510  X2.7230  Y3.8075 ( X:2.7230   Y:3.8075 )
N1515  X2.7153  Y3.8106 ( X:2.7153   Y:3.8106 )
N1520  X2.7109  Y3.8139 ( X:2.7109   Y:3.8139 )
N1525  X2.7082  Y3.8180 ( X:2.7082   Y:3.8180 )
N1530  X2.7072  Y3.8215 ( X:2.7072   Y:3.8215 )
N1535  X2.7065  Y3.8266 ( X:2.7065   Y:3.8266 )
N1540  X2.7061  Y3.8331 ( X:2.7061   Y:3.8331 )
N1545  X2.7060  Y3.8412 ( X:2.7060   Y:3.8412 )
N1550  Y3.9138 ( Y:3.9138 )
N1555  X2.7480 ( X:2.7480 )
N1560  X2.7535  Y3.9135 ( X:2.7535   Y:3.9135 )
N1565  X2.7583  Y3.9129 ( X:2.7583   Y:3.9129 )
N1570  X2.7622  Y3.9119 ( X:2.7622   Y:3.9119 )
N1575  X2.7655  Y3.9106 ( X:2.7655   Y:3.9106 )
N1580  X2.7708  Y3.9066 ( X:2.7708   Y:3.9066 )
N1585  X2.7748  Y3.9012 ( X:2.7748   Y:3.9012 )
N1590  X2.7763  Y3.8976 ( X:2.7763   Y:3.8976 )
N1595  X2.7773  Y3.8930 ( X:2.7773   Y:3.8930 )
N1600  X2.7780  Y3.8877 ( X:2.7780   Y:3.8877 )
N1605  X2.7783  Y3.8814 ( X:2.7783   Y:3.8814 )
N1610  X2.7846 ( X:2.7846 )
N1615  Y3.9597 ( Y:3.9597 )
N1620  X2.7783 ( X:2.7783 )
N1625  X2.7769  Y3.9509 ( X:2.7769   Y:3.9509 )
N1630  X2.7750  Y3.9438 ( X:2.7750   Y:3.9438 )
N1635  X2.7724  Y3.9383 ( X:2.7724   Y:3.9383 )
N1640  X2.7693  Y3.9343 ( X:2.7693   Y:3.9343 )
N1645  X2.7655  Y3.9316 ( X:2.7655   Y:3.9316 )
N1650  X2.7606  Y3.9295 ( X:2.7606   Y:3.9295 )
N1655  X2.7549  Y3.9284 ( X:2.7549   Y:3.9284 )
N1660  X2.7480  Y3.9279 ( X:2.7480   Y:3.9279 )
N1665  X2.7060 ( X:2.7060 )
N1670  Y4.0188 ( Y:4.0188 )
N1675 G0  Z1.0000 ( G00:Rapid positioning Z:1.0000 )
N1680  X2.6215  Y3.8642 ( X:2.6215   Y:3.8642 )
N1685  Z0.0000 ( Z:0.0000 )
N1690 G1  X2.6170  Y3.8542 ( G01:Linear interpolation X:2.6170   Y:3.8542 )
N1695  X2.6126  Y3.8456 ( X:2.6126   Y:3.8456 )
N1700  X2.6081  Y3.8384 ( X:2.6081   Y:3.8384 )
N1705  X2.6037  Y3.8327 ( X:2.6037   Y:3.8327 )
N1710  X2.5991  Y3.8281 ( X:2.5991   Y:3.8281 )
N1715  X2.5944  Y3.8243 ( X:2.5944   Y:3.8243 )
N1720  X2.5893  Y3.8212 ( X:2.5893   Y:3.8212 )
N1725  X2.5841  Y3.8188 ( X:2.5841   Y:3.8188 )
N1730  X2.5777  Y3.8171 ( X:2.5777   Y:3.8171 )
N1735  X2.5694  Y3.8159 ( X:2.5694   Y:3.8159 )
N1740  X2.5590  Y3.8151 ( X:2.5590   Y:3.8151 )
N1745  X2.5468  Y3.8149 ( X:2.5468   Y:3.8149 )
N1750  X2.5298 ( X:2.5298 )
N1755  X2.5198  Y3.8150 ( X:2.5198   Y:3.8150 )
N1760  X2.5122  Y3.8153 ( X:2.5122   Y:3.8153 )
N1765  X2.5066  Y3.8159 ( X:2.5066   Y:3.8159 )
N1770  X2.5033  Y3.8166 ( X:2.5033   Y:3.8166 )
N1775  X2.4996  Y3.8187 ( X:2.4996   Y:3.8187 )
N1780  X2.4970  Y3.8219 ( X:2.4970   Y:3.8219 )
N1785  X2.4959  Y3.8251 ( X:2.4959   Y:3.8251 )
N1790  X2.4950  Y3.8294 ( X:2.4950   Y:3.8294 )
N1795  X2.4945  Y3.8348 ( X:2.4945   Y:3.8348 )
N1800  X2.4943  Y3.8413 ( X:2.4943   Y:3.8413 )
N1805  Y3.9865 ( Y:3.9865 )
N1810  X2.4945  Y3.9959 ( X:2.4945   Y:3.9959 )
N1815  X2.4950  Y4.0034 ( X:2.4950   Y:4.0034 )
N1820  X2.4959  Y4.0090 ( X:2.4959   Y:4.0090 )
N1825  X2.4970  Y4.0126 ( X:2.4970   Y:4.0126 )
N1830  X2.5009  Y4.0176 ( X:2.5009   Y:4.0176 )
N1835  X2.5072  Y4.0217 ( X:2.5072   Y:4.0217 )
N1840  X2.5115  Y4.0232 ( X:2.5115   Y:4.0232 )
N1845  X2.5173  Y4.0243 ( X:2.5173   Y:4.0243 )
N1850  X2.5244  Y4.0250 ( X:2.5244   Y:4.0250 )
N1855  X2.5329  Y4.0251 ( X:2.5329   Y:4.0251 )
N1860  Y4.0314 ( Y:4.0314 )
N1865  X2.4283 ( X:2.4283 )
N1870  Y4.0251 ( Y:4.0251 )
N1875  X2.4369 ( X:2.4369 )
N1880  X2.4431  Y4.0247 ( X:2.4431   Y:4.0247 )
N1885  X2.4484  Y4.0232 ( X:2.4484   Y:4.0232 )
N1890  X2.4530  Y4.0208 ( X:2.4530   Y:4.0208 )
N1895  X2.4568  Y4.0176 ( X:2.4568   Y:4.0176 )
N1900  X2.4589  Y4.0139 ( X:2.4589   Y:4.0139 )
N1905  X2.4604  Y4.0080 ( X:2.4604   Y:4.0080 )
N1910  X2.4612  Y4.0003 ( X:2.4612   Y:4.0003 )
N1915  X2.4616  Y3.9905 ( X:2.4616   Y:3.9905 )
N1920  Y3.8413 ( Y:3.8413 )
N1925  X2.4613  Y3.8323 ( X:2.4613   Y:3.8323 )
N1930  X2.4607  Y3.8251 ( X:2.4607   Y:3.8251 )
N1935  X2.4595  Y3.8197 ( X:2.4595   Y:3.8197 )
N1940  X2.4579  Y3.8161 ( X:2.4579   Y:3.8161 )
N1945  X2.4543  Y3.8119 ( X:2.4543   Y:3.8119 )
N1950  X2.4495  Y3.8089 ( X:2.4495   Y:3.8089 )
N1955  X2.4438  Y3.8072 ( X:2.4438   Y:3.8072 )
N1960  X2.4369  Y3.8066 ( X:2.4369   Y:3.8066 )
N1965  X2.4283 ( X:2.4283 )
N1970  Y3.8003 ( Y:3.8003 )
N1975  X2.6073 ( X:2.6073 )
N1980  X2.6270  Y3.8629 ( X:2.6270   Y:3.8629 )
N1985 G40 ( G40:Tool radius comp off )
N1990  X2.6215  Y3.8642 ( X:2.6215   Y:3.8642 )
N1995 G0  Z1.0000 ( G00:Rapid positioning Z:1.0000 )
N2000  X3.2396  Y3.8153 ( X:3.2396   Y:3.8153 )
N2005  Z0.1000 ( Z:0.1000 )
N2010 G42 ( G42:Tool radius compensation right )
N2015 G1  X3.2341  Y3.8159  Z0.0000 ( G01:Linear interpolation X:3.2341   Y:3.8159   Z:0.0000 )
N2020  X3.2218  Y3.9865 ( X:3.2218   Y:3.9865 )
N2025  X3.2220  Y3.9959 ( X:3.2220   Y:3.9959 )
N2030  X3.2225  Y4.0034 ( X:3.2225   Y:4.0034 )
« Reply #5 on: March 17, 2012, 01:29:59 PM »
Ive made no changes to Lazycam after I downloaded it just opened a dxf and generated a tap file. I suspect thats where I need to change or set up things. I just downloaded the lazycam manual and will be looking it over. If someone knows more precisely where to look or what specifically needs to be changed that would be great. Thanks John
« Reply #6 on: March 18, 2012, 06:49:19 PM »
Well I figured out my problem it was because I never set up the start cut height,depth etc. In lazycam. Thanks
