Hello Guest it is October 20, 2026, 09:20:21 PM
Author Topic: Mach3 homing direction  (Read 12183 times)
« on: March 12, 2012, 04:18:14 PM »
Hello, all: I'll make this as short as possible. I go to reference my 3 axis, and the Z and Y move as they should, but I have to set the "reversed" option in Homing/Limits to make the X go in the correct direction. However, if I use the Mach3 Jog pendant, the Y goes in the opposite direction (tries to home towards Y +)  I've tried changing the Active Low in Ports and Pins/Motor Outputs, then changed it back, and I've also tried switching two wires to my 4-wire steppers, all with no solution.  Any ideas?  Why would I get opposite directions using the Jog?
Re: Mach3 homing direction
« Reply #1 on: March 19, 2012, 07:15:38 AM »
What pendant and how does the button to home work in it as I think it must be a script of some sort?
« Reply #2 on: March 20, 2012, 07:46:19 AM »
Hood:  I meant the internal "pendant" in mach3 accessed by the "Tab" key.  In any case, I finally got my settings correct, and now things are working as they should.
« Reply #3 on: October 20, 2012, 08:02:45 PM »
I have got a similar problem.  How did you resolve yours.
