Hello Guest it is October 22, 2026, 08:40:26 PM
Author Topic: Running circle wizard  (Read 12087 times)
Offline PCH
  •  80 80
« on: March 09, 2012, 09:31:36 AM »
keep get error messages in the circle wizard. No matter what I change I get the Vb error or radius from end of arc differs from radius on line 5
I need a tutorial on these wizards.  >:(
Re: Running circle wizard
« Reply #1 on: March 09, 2012, 09:45:33 AM »
The wizard spits out code in Inc. IJ mode.
Try G91.1 at the beginning of the file, or select Inc IJ in Gen Config.
Russ
« Reply #2 on: August 01, 2018, 08:15:07 PM »
Hello i am having problems with cutting circle pockets. Can someone please help me. I need to show you what is happening, dont know how to upload a photo yet.
« Reply #3 on: August 01, 2018, 08:30:32 PM »
Dont know if it worked but i attached a photo. So anyway whats happening in when i use the mach3 wizard for circle pocket ( 15mm dia, 4mm deep) when the tool does it frist cut all goes well. When it dose the second cut it start to go in a ovel shape, but it does it on all cuts. I set it to cut a 1mm step down.
  •  9,374 9,374
« Reply #4 on: August 02, 2018, 12:41:47 AM »
I would suspect that the problem is mechanical, maybe a loose coupling ?
Check that you are not loosing steps - does the machine return eaxctly to the zero position after it has finished making the oval pockets ?
