Hello Guest it is November 13, 2026, 09:59:32 AM
Author Topic: cycle start g01 z0.000 error  (Read 10441 times)
« on: March 08, 2012, 09:02:34 AM »
After my spindle start line, my cam puts in the g01 z0.00 line.
All my Dro's are set to zero, when I hit cycle start it stops at this line and says it cannot complete this task.
My quick fix was to jog z to .001" then run program and it worked fine.
My gcode always has this line in there, this is first time this has happened.
Why would it do that?
  •  9,377 9,377
Re: cycle start g01 z0.000 error
« Reply #1 on: March 08, 2012, 09:30:20 AM »
A possible cause is that you have not declared a feed rate for the G01 move.
Try putting F600 before the G01 move.
« Last Edit: March 08, 2012, 09:32:22 AM by Tweakie.CNC »
« Reply #2 on: March 08, 2012, 06:14:38 PM »
this is typically what my programs start off with, and it's never had a problem before.
G00 G49 G40.1 G17 G80 G50 G90 G64
G20
(.325 drill)
M6 T3
M03 S800
G01Z0.000
G00X-0.142Y-3.277
Z0.200
Z0.020
G01Z-0.050 F3
G00Z0.020
Z-0.030
A little bit more info... the same program wouldn't start spindle... some error came up couldn't find m3 module or something like that.
i restarted mach... spindle then worked.... but then I got the go1 z0.00 cycle start error.
« Reply #3 on: March 08, 2012, 08:21:48 PM »
Try presetting your feedrate to something other than ZERO before you load the code. OR as Tweakie suggested put a F call at the start of the program BEFORE the G1
MACH must have a feedrate set before it can run a motion Gcode such as G1s or else you will get an error.
Just a thought, (;-) TP
