Hello Guest it is October 30, 2026, 01:51:46 PM
Author Topic: power supply tolerance  (Read 14967 times)
« on: March 06, 2012, 09:25:00 AM »
just bought a second hand multi output power supply from ebay
but there is quite a bit of difference between req'd output and
actual measured
req'd voltage (dc)   actual measured voltage (dc)
+12v                     +14.06v
+12v                     +13.79v
+24v                     +27.8v
+50v                     +48.5v
-12v                       -13.7v
+5v                       +5.2v
will this level of overvoltage damage breakout boards etc?
what is the normal tolerance on power supplies
cheers George
Re: power supply tolerance
« Reply #1 on: March 06, 2012, 10:18:18 AM »
Are you checking the voltages with a load on the outputs? It will likely fall down nearer to specs when there is a load.
« Reply #2 on: March 06, 2012, 10:43:37 AM »
Hi Hood
no I was just testing across terminals?
the power outputs are
+12v @ 12A
-12v  @ 2A
+24v  @ 3A
+50v  @ 10A
+5v   @ 3A
what would you recommend for a load to test?
(sorry for basic question but not electrical)
cheers  G
« Reply #3 on: March 06, 2012, 10:54:46 AM »
What you have is clearly an unregulated supply, which will reach the rated voltage only at, or near, full load.  Most electronic devices are spec'd at +/- either 5% or 10% on supply voltage, and you are well over that on all but the 5V output.  In particular, most ICs are spec'd for no more than +/-10%, and are VERY likely to be damaged if this is exceeded.  I would not use that supply to directly power any electronics, without knowing that they can tolerate the over-voltage.
Either get another supply, or add regulators to that one (and this is not really practical, or cost-effective at those current levels....).
« Reply #4 on: March 06, 2012, 12:38:02 PM »
Ok many thanks for the help
George
« Reply #5 on: March 07, 2012, 05:44:44 AM »
can someone tell me
is a linear power supply the same as a regulated power supply
cheers G
« Reply #6 on: March 07, 2012, 09:05:59 AM »
"is a linear power supply the same as a regulated power supply" - absolutely not.  A regulated supply may, or may not, be linear, and a linear supply may, or may not, be regulated.  "Linear" indicates it is not a switching power supply, but says nothing about whether or not it is regulated.
