Hello Guest it is November 13, 2026, 12:59:55 PM
Author Topic: Shortcut to profile location, issue  (Read 16196 times)
Offline Fastest1
  •  920 920
  • Houston, TX
« on: March 05, 2012, 05:11:33 PM »
I want a shortcut to a specific profile. If I try to copy Mach3.exe it tells me Enable40.dll is missing. However if I click the icon in c/mach3.exe it opens fine (the loader does, I really only want 1 profile to install on my touchscreens desktop ). Furthermore, I see Enable40.dll adjacent. I also see the exact xml I am trying to get the profile for to install on my desktop. Any tips? I can reload Mach but would prefer not to.
Re: Shortcut to profile location, issue
« Reply #1 on: March 05, 2012, 05:55:45 PM »
HI,
 Not sure if this is what you are wanting ... ?
Russ
« Reply #2 on: March 05, 2012, 06:11:25 PM »
.... if it is, just put whatever profile you want at the end.
C:\Mach3\Mach3.exe  /p Mach3Mill
                                   or       Turn
                                   or        YourProfile
Must be exactly like above, don't forget the spaces !
Russ
« Last Edit: March 05, 2012, 06:17:05 PM by Overloaded »
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #3 on: March 05, 2012, 07:54:39 PM »
Russ, thanks for the help. Does my use of a Smoothstepper change anything about the location?
« Reply #4 on: March 05, 2012, 08:12:19 PM »
Nope, don't think so.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #5 on: March 06, 2012, 02:40:05 PM »
Worked great, thanks.
