Hello Guest it is November 13, 2026, 12:52:34 PM
Author Topic: Mach 2 Fan Running All The Time  (Read 20251 times)
« on: March 05, 2012, 12:06:38 PM »
Hello !  I have a Mach 2 ,that has been sitting for a while unused. I plugged it in and a fan or something is running inside box all the time.  This never happened before. Any info. greatly appreciated !
Re: Mach 2 Fan Running All The Time
« Reply #1 on: March 05, 2012, 12:31:38 PM »
Think you would have to supply a bit more info on what you have. Mach2 is the control software and has nothing to do with fans running as such.
« Reply #2 on: March 05, 2012, 12:43:29 PM »
Sorry, It is a CNC micro Milling Machine,4 axis, with a Soft Step 4x483 control box. A fan or motor keeps running inside the control box. Thank You !
« Reply #3 on: March 05, 2012, 01:03:04 PM »
Got a link to info on it
« Reply #4 on: March 05, 2012, 01:39:41 PM »
Could it possibly be that the fan is noisy from sitting dormant, and always did run but much quieter before ?
Just a recollection from a previous experience,  ::)
Russ
« Last Edit: March 05, 2012, 01:43:15 PM by Overloaded »
« Reply #5 on: March 05, 2012, 02:09:00 PM »
Could be ?  I am thinking there may be dust built up inside also...I guess that is my next step,to pull cover off,just to see if dusty. Thanks for the post !
« Reply #6 on: March 05, 2012, 05:08:44 PM »
a drop of oil in the bushing should fix it
« Reply #7 on: March 05, 2012, 07:42:35 PM »
Thanks !  I really do not think anything should be running just sitting there plugged in though ?
« Reply #8 on: March 06, 2012, 04:03:56 AM »
Yes, if it's a cooling fan for the drives, it will run the whole time to keep things cool and/or to exhaust any heat from the control box.
« Reply #9 on: March 06, 2012, 08:55:12 AM »
Yes it is the cooling fan for the drives. I never heard it running before while it was just sitting there plugged in. No program running. That is what has me puzzeled. It will run all the time. I am afraid it will burn the motor up. I have to keep it unplugged. Thank You !
