Hello Guest it is November 13, 2026, 12:31:52 PM
Author Topic: mach3 foam cutter heat control.  (Read 9829 times)
« on: March 04, 2012, 02:25:27 AM »
I'm korean user mach3. I'm not good at english. I hope you understand my question.
I control heat by dial. very Often i change dial so i cannot choose exact volume.
I hope to control heat by mach3 (use spilndle control)
Do i need any other equipment? (ex. converter ,inverter, ??)
Re: mach3 foam cutter heat control.
« Reply #1 on: March 04, 2012, 03:55:22 AM »
If your control takes 0 to 10v or something similar then you could probably use one of the spindle speed boards available.
