Hello Guest it is November 13, 2026, 02:01:39 PM
Author Topic: UIRobot UIM290405A Mach3 Breakout Board + Spindle Control  (Read 11782 times)
« on: March 03, 2012, 09:28:05 AM »
Hi everyone :)
I got my UIRobot UIM290405A Mach3 Breakout Board from Zapp Automation Ltd - Stepper motors & Stepper Motor Drivers - Servo motors and Servo Motor Drivers - Ballscrews & linear motion products. : and am currently bench testing, before I build it into an enclosure.
The manual (http://www.zappautomation.co.uk/pdf/UIM2901%20Mach3%20BOB%20120104.pdf) is translated Chinese, I guess but is really not very clear. For example the parallel pinout diagram shows X step/dir to be pins 3/2, but later in the Mach configuration, it shows an image with it as 2/6 !!
Anyway, right now I am trying to test the PWM spindle control, which I am hoping to use to connect directly to my Seig X1 controller, replacing the pot.
I have connected it to the parallel port, and with 5v power from USB, and 12v from a lead acid battery. I also connected the 12v bettery to the spindle control Vin and 0v, then connected my multimeter to 0v and Out.
First problem:
The output voltage range was reversed. So M5 was outputting 12v! I resolved this by setting Step Low Active on my spindle in Motor Outputs in Mach3.
Second problem (no solution yet):
With M5, or even Charge pump off (E-stop) the output voltage is still 5.2v! as shown in picture. M3S2000 makes it 12v as I would expect. (2000 is max rpm).
The voltage does get controlled by Mach3, but in the range of 5-12v. :(
I can't use this if the lowest is 5v. My spindle will never stop. Why is it not 0-12v?
Please help :) Thanks :)
  •  9,377 9,377
Re: UIRobot UIM290405A Mach3 Breakout Board + Spindle Control
« Reply #1 on: March 11, 2012, 04:53:53 AM »
Hi Memran,
As you don't seem to be getting any response on this one try contacting Zapp directly.
I had a question (regarding the holding pulse frequency for one of their stepper drivers) last week, contacted them via their website query and received an email answer same day.
« Reply #2 on: March 11, 2012, 02:42:47 PM »
Thanks, good idea :)
