Hello Guest it is November 10, 2026, 01:55:10 AM
Author Topic: OemDro(98) ??  (Read 10905 times)
OemDro(98) ??
« on: February 29, 2012, 08:17:27 PM »
Have anyone actually gotten this DRO to change the FRO inc value?????
Thanks, (;-) TP
Re: OemDro(98) ??
« Reply #1 on: March 01, 2012, 06:50:54 AM »
Mine is on 5 when I check it
« Last Edit: March 01, 2012, 06:55:45 AM by Ya-Nvr-No »
Re: OemDro(98) ??
« Reply #2 on: March 01, 2012, 09:23:27 AM »
Same here BUT the FRO inc value is actually 10. ????? I have tried changing it BUT it makes no difference to the FRO% inc.
OH Well, (;-)
Re: OemDro(98) ??
« Reply #3 on: March 01, 2012, 10:36:30 AM »
YNN that is an interesting Plugin you got there. Care to share ?  Or can you check for a dro that has a value of 10 ?????
Re: OemDro(98) ??
« Reply #4 on: March 01, 2012, 04:16:38 PM »
As you can see it checks for any DRO or LED not equaling zero
I created the plugin for computing 5 axis tool nose position and then drive all the axis's to the position based on 4th and/or 5th axis head rotation, I just added the get data button to see current data values. It was a test in learning multi-axis matrix programming. Took me months to understand how to get it to work. I've found, I'm not that smart, but I manage to muck way thru it.  ;-)
Re: OemDro(98) ??
« Reply #5 on: March 01, 2012, 06:01:05 PM »
So do you see any dros with a value of 10 hanging out somewhere??? Hoping it is stored in a Dro somewhere and NOT hardcoded.
Re: OemDro(98) ??
« Reply #6 on: March 01, 2012, 06:46:54 PM »
Only thing I see related to the FRO;s are in my case
223 Rapid FRO 0-100
821 Feed FRO 0-150
