Hello Guest it is November 18, 2026, 12:44:18 PM
Author Topic: a axix does not respond with smooth stepper  (Read 11214 times)
« on: February 29, 2012, 10:54:16 AM »
upgraded to smooth stepper followed all directions and not the a axis does not respond all others do if I switch back to the port they all move fine.  It is a warp 9 smooth stepper.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: a axix does not respond with smooth stepper
« Reply #1 on: March 01, 2012, 08:09:03 AM »
I use my A-axis all the time with both a USB and Ethernet SmoothStepper. Take a look at your configuration in the SmoothStepper configuration section. I've also had Mach do funny things at times when I 'cloned' a profile. I've seen various Ports/Pins just not work with the cloned profile. Starting a new profile from Scratch did the trick.
Happy machining , Jeff Birt
