Hello Guest it is November 11, 2026, 07:02:35 PM
Author Topic: Button to send tool to tool change - feedrate oddity ...  (Read 9741 times)
« on: February 27, 2012, 06:08:29 PM »
Is there a OEM or Standard button that is used to send a tool to the tool change position ?  I have tried to use X Home or Y Home etc. but the axis moves at an unbelievable
speed when I tried those, almost instantaneous homing.
I must be missing something........
I have tried adjusting the jog feedrates and every other feedrate that I could find but nothing changes this behavior.
Re: Button to send tool to tool change - feedrate oddity ...
« Reply #1 on: February 27, 2012, 07:11:15 PM »
Not standard, but
I put a "TCP" button on the RUN screen with the following script.
'For using TCP on Settings Screen
x=GetUserDRO(1200)
y=GetUserDRO(1201)
z=GetUserDRO(1202)
code"G90"
code"G0"
code"G53Z"&z
code"G53X"&x &"Y"&y
Then enter the position you want for the tool change in the dro's on the settings screen.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #2 on: February 28, 2012, 06:51:02 AM »
Under homing/limits what do you have set for your homing speed? in %
