Hello Guest it is November 22, 2026, 07:04:01 AM
Author Topic: wizards don't seem to work  (Read 10006 times)
« on: February 27, 2012, 01:57:08 AM »
hi all,
i am a newby for sure... i am building a sieg 2x minimill into a cnc mill like hasses machine..
i decided to use mach3 and machstanderdmill software to run it.. i got mach installed and licences and also licesnced the mill wizard addons..
when i open up a wizard i see all the preloaded example inputs but i can not change any of them ...
don't know what i did wrong.. i know that the mach3 is working on my mill did a simple cut just to see it work. i have not set up the z axis yet as i was going to use the X/Y to cut the hardware for that axis.. but can't use any of the wizards
any help????
larry in the boonies of alaska, under 6 feet of snow this winter ;D
Re: wizards don't seem to work
« Reply #1 on: February 27, 2012, 02:09:59 AM »
Hi Mate
Can you put new numbers in the dro's? and they don't change when you click out of them? - you must hit the enter key when you change a dro. Hope this helps.
Steve
« Reply #2 on: February 27, 2012, 02:14:12 AM »
AHHHHH AAAA i seeee said the blind man to the deaf brother.. yes that seems to be the ticket i think
thank you thank you so very much
