Hello Guest it is November 12, 2026, 09:59:10 AM
Author Topic: G84 Canned RH Tapping Cycle  (Read 35496 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G84 Canned RH Tapping Cycle
« Reply #10 on: May 10, 2007, 01:39:30 AM »
The G84 tapping cycle is calculated like this
G84 Depth in Z, Start point, Thread pitch * rpm
Tap is 20 tpi so 1/20=.050"
rpm=100
So feed = .050*100 = 5.0 (F5.0)
G84 Z-.75 R.100 F5.
As for cutting speeds
Aluminium  70-90 ft/min (21-27m/min)
Brass         80-100 (24-30)
Bronze       30-40 (9-12)
Iron           15-30 (4.5-9)
Mild steel    20-40 (9-15)
Steel Alloys 15-25 (4.5-8)
Stainless     10-15 (3-4.5)
BSPT and NPT taps should run at 50-60% of the above figures.
I hope this helps
Graham.
chadley71
« Reply #11 on: May 10, 2007, 07:23:02 AM »
THANKS GRAHAM
