Hello Guest it is November 13, 2026, 09:46:49 AM
Author Topic: Video Issue  (Read 8899 times)
Video Issue
« on: February 18, 2012, 10:13:26 PM »
When I use the Video Plugin with a usb machine camera in Mach the X & Y axis become unstable and start to jitter while making a move. The only way to get the X & Y axis to move properly after using the video plugin is to exit Mach and restart Mach then everything works fine until I use the video plugin again. It appears like there is some sort of a driver conflict on the usb side of things but I cannot see where the conflict is. The machine camera did not require a driver to work in Mach, just had to plug it in. Has anyone else run into this issue, if so where do I start looking to cure the problem?
Re: Video Issue
« Reply #1 on: February 19, 2012, 02:34:10 AM »
I have heard of people having this issue if they have just USB1 ports rather than USB2.
Re: Video Issue
« Reply #2 on: February 19, 2012, 05:35:50 PM »
I have USB2
