Hello Guest it is November 22, 2026, 02:26:57 PM
Author Topic: Setting of edge finder diameter  (Read 9150 times)
« on: February 18, 2012, 04:53:14 AM »
Hello,
I have the R3.043.022 of Mach3. I don't know how to set edge finder diameter (offsets index).
If i click in the window i can't enter a value. I have not seen a way to specify this in the configuration.
Thank you for your help !
Michel
Re: Setting of edge finder diameter
« Reply #1 on: February 19, 2012, 02:15:57 AM »
Adendum: for S and Tool settings it is the same, i can't enter a value directly in the window (when i click in the window the background color changes but i can't enter figures).
I must use "M6 T1" and S8000 in the MDI window to set these parameters (and the corresponding windows are updated).
With the "edge finder diameter" i have not found an MDI command....
« Reply #2 on: February 19, 2012, 06:05:48 AM »
Some news, i have found the problem and i think i am a little bit stupid !
The reason is the keyboard was not in "numerical lock" !
I have several computers and i usually have the numerical keypad lock for others, so i don't look at the keypad lock led.
It is really stupid.
« Reply #3 on: February 19, 2012, 10:18:57 AM »
Don't kick yourselk I still do it from time to time. AND it is still a surprise when I do it.
