Hello Guest it is November 22, 2026, 02:26:05 PM
Author Topic: using dolphin turn to make trochoidal milling code?  (Read 14038 times)
« on: February 16, 2012, 07:40:11 PM »
it seem to work to just change the code from xz to xy in wordpad.
change the g18 to g17 and such.
anyone ever try this?
Re: using dolphin turn to make trochoidal milling code?
« Reply #1 on: February 16, 2012, 08:51:33 PM »
cad drawing
cam
« Reply #2 on: February 16, 2012, 08:52:32 PM »
code from the lathe cam
« Last Edit: February 16, 2012, 08:54:16 PM by turbothis »
« Reply #3 on: February 16, 2012, 09:41:27 PM »
ok, simpler code
i took the DT g code and pasted it into a milling folder with the right goods.
converted the IJK's and the XYZ"s in wordpad reall quick.
the only strange thing is i had to set DT tool profile to rear instead of front.
it seems to work flawless. ;D
« Last Edit: February 16, 2012, 09:44:09 PM by turbothis »
« Reply #4 on: February 16, 2012, 09:49:59 PM »
i just cleaned up the scraps on the code conversion and it seems air tight.
now how do we get a post processor or something to do this quick and easy?
i can do this now in about 5 minutes
« Last Edit: February 16, 2012, 09:57:53 PM by turbothis »
« Reply #5 on: February 16, 2012, 09:52:20 PM »
final cam set up
« Reply #6 on: February 16, 2012, 09:59:55 PM »
it seem to me you would just have to attack each side indavidually but it is pretty simple. just change the tool profile in the cam.
