Hello Guest it is October 25, 2026, 02:59:32 AM
Author Topic: wizards erasing fields  (Read 14681 times)
« on: February 13, 2012, 08:49:25 PM »
Hello all after almost a year of messing with my new Taig i have finely gotten the thing to run all axis correctly and now i am having issues with trying to run any wizards. example on engraving wizard i input the text but i cannot change any thing else in boxes, also where do i input the size and thickness of my material. any help would be appreciated.
Re: wizards erasing fields
« Reply #1 on: February 13, 2012, 09:00:24 PM »
It sounds like you are not pressing the Enter key. Mach does not update a value you place in a DRO until you also press the Enter key. If you simply click the mouse to another DRO it will revert to its original value.
By engraving wizard I assume you mean the Write wizard. Happily for me that is not one of the supported Newfangled wizards. It does cause a lot of trouble to people trying to use it. There are many notes on this forum about using it. I have not used it so Im not able to help. I do believe it does work well once you learn to use it.
