Hello Guest it is November 22, 2026, 08:56:10 AM
Author Topic: Pressing reset sets machine coords to zero  (Read 23414 times)
« on: February 10, 2012, 10:05:15 AM »
Why does pressing the big red reset button set my machine coords to zero?  ??? This is a big waste of time if for some reason I need to press the reset button in the middle of a job. I have to re-home the machine. Fortunately the user coords stay put so I can usually continue where I left off.
Dennis
Re: Pressing reset sets machine coords to zero
« Reply #1 on: February 10, 2012, 10:18:24 AM »
You are going to have to ask the person that BUILT the machine and configured the button. (;-)
« Reply #2 on: February 10, 2012, 10:36:12 AM »
Yeah, but the guy in the mirror is just as confused as I am?  ;)
Your answer does give me a better idea what the problem is.
Dennis
« Reply #3 on: February 10, 2012, 12:52:12 PM »
 Chech the button and also the Initialization String, and if Use on ALL "Resets" is checked.
Russ
« Reply #4 on: February 10, 2012, 01:05:11 PM »
If you have pressed Reset when an axis is moving then it is only wise to rehome.
« Reply #5 on: February 10, 2012, 04:07:13 PM »
It's usually a good idea to mention that you're using a KFLOP and the dynomotion plugin.
« Reply #6 on: February 10, 2012, 05:19:44 PM »
 ::) a pertenant little tid-bit indeed
« Last Edit: February 10, 2012, 05:39:37 PM by Overloaded »
« Reply #7 on: February 11, 2012, 01:48:20 AM »
Yes, I would typically agree that is a very pertinent piece of information. I was approaching the question from more of a using Mach3 only perspective.
I really appreciate your guys help.
Dennis
« Reply #8 on: February 11, 2012, 06:17:03 AM »
Are you not using a KFLOP? Your post on CNC Zone was in the Dynomotion forum.
A standard Mach3 install will not change any coordinates when hitting E-Stop.
« Reply #9 on: February 11, 2012, 06:25:43 AM »
Dennis
Bad idea....  I believe in the KFlop plug-in settings there is a checkbox to enable re-running your Init.c whenever E-Stop is activated.  Un-check that.
