Hello Guest it is November 27, 2026, 09:42:25 AM
Author Topic: mach3 macromodbus emulation‏  (Read 10413 times)
« on: February 10, 2012, 02:22:06 AM »
I am designing a prototype but I realize that I need fast velocity in communication if I will use step or servo motor.
I was thinking to use modbus serial but I investigated that is slowly for critical process.
I was  thinking to use TCPModbus but I think it has the same problem.
A friend in foro said to me that he had a AJAC hardware and It works perfectly. He said me that it works with Ethernet and it is fastest.
Ajax use macromodbus emulation!
Can you help me about information about macromodbus emulation??
I hope to design software without parallel port. I hope to use Ethernet with my servo or step motor.
Thank you in advantage.
