Hello
Guest
it is
August 14, 2026, 08:23:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
cutting uniform mortise in wood
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: cutting uniform mortise in wood (Read 10659 times)
woodguy7777
75
on:
February 07, 2012, 06:46:51 AM »
i have been cutting a 1x2 inch mortise.
at 1 inch per min. but i am not getting a uniform cut.
just wonder what adjustment i can make to correct this.
thanks paul
Last Edit: February 07, 2012, 06:49:37 AM by woodguy7777
Carnoustie, Scotland
Re: cutting uniform mortise in wood
Reply #1 on:
February 07, 2012, 08:41:53 AM »
Do you have backlash?
woodguy7777
75
Reply #2 on:
February 07, 2012, 08:54:27 AM »
Are you referring to mechanical backlash.
like play in the drive gears ? i will check to see if there is any play there
can the velocity and acceleration setting cause this
thanks paul
Reply #3 on:
February 07, 2012, 10:33:09 AM »
I am not sure exactly what the issue is, it does look in the pic that opposite corners are much more rounded than the other two, is that the problem?
woodguy7777
75
Reply #4 on:
February 07, 2012, 11:45:03 AM »
yes hood that is the problem.
the problem seem to happen when the bit goes around the corners
so i am not getting a clean rectangle.
i seem to have this problem anytime i am cutting out a small area.
if i was cutting out a 12x12 area its ok.
it seem as if as the bit picks up speed on the 1 inch side it then suddenly does int the curve and that is what cause the problem.
thanks again paul
my backlash is set to 20 percent
shopbot cnc stepper motors
Last Edit: February 07, 2012, 11:58:41 AM by woodguy7777
Reply #5 on:
February 07, 2012, 01:06:51 PM »
Not sure on backlash settings with the PP as I have never used them but certainly seems like backlash to me.
Print
Pages:
1
Go Up
« previous
next »
