Hello Guest it is November 13, 2026, 12:14:31 PM
Author Topic: Some guidance on spindles  (Read 13837 times)
« on: January 30, 2012, 05:18:38 AM »
Hi all,
I am in the throws of making a CNC router for use with plastics and was wondering what others did to power their spindles?  I am currently using a cheapo dremel equivalent which is running way too fast.  At the moment I am intending to use the machine on plastics.
Z
Offline olf20
  •  325 325
Re: Some guidance on spindles
« Reply #1 on: January 30, 2012, 05:51:38 AM »
We use a Porter Cable 2.75hp router motor. However like you
it runs too fast for some of our work. Have been looking at
other options but have not found anything that would be better
that we could afford.
Hope someone posts some new info.
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #2 on: January 30, 2012, 09:07:51 AM »
Both Dremels and routers are readily available with variable speed controls....
« Reply #3 on: January 30, 2012, 10:09:22 AM »
I agree.  The dremel clone I have is variable speed but the torque available at the lowest speed (which is still fast) is too low so I end up jacking the speed to compensate.
So I was hoping to find something which was capable of reasonable torque at low speeds.  And preferably cheap to boot.
Z
« Reply #4 on: January 30, 2012, 10:56:03 AM »
If you disregard the cheap, adding a Super-PID to most any router will give you plenty of power down to 5000 rpm.
www.superpid.com
Offline olf20
  •  325 325
« Reply #5 on: January 30, 2012, 02:16:38 PM »
Hi Gerry
What motor do you use with the SPID???
Thanks olf20 / Bob
« Reply #6 on: January 30, 2012, 03:44:32 PM »
Porter Cable 690
« Reply #7 on: January 31, 2012, 12:33:55 PM »
Take a look at the Sherline heads.  I have two Sherline milling machines and I like their heads a lot when lower speeds are needed.
