Hello Guest it is November 23, 2026, 08:11:16 PM
Author Topic: Importing files from Turbocad  (Read 10661 times)
« on: January 29, 2012, 08:36:19 PM »
can I use my 2D/3D files from Turbocad with Mach 3 to make G codes
Re: Importing files from Turbocad
« Reply #1 on: January 30, 2012, 04:04:42 AM »
Mach3 is a Windows based CNC controller.You need to use addtional software to create Gcode from 2d/3d files. Mach includes programs such as LazyCam which can import a 2d dxf,
define the machining, and then export Gcode to Mach3. Thus you need other software.
« Reply #2 on: February 04, 2012, 09:02:08 AM »
Thanks. Will GWizard work to go from Turbocad and Mach 3?? I've found a few others but  Gwizard does feeds and speeds
« Reply #3 on: February 04, 2012, 09:49:31 AM »
Someone correct me if I'm wrong, but GWizard doesn't create g-code, does it?
