Hello
Guest
it is
November 22, 2026, 06:25:13 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
G31 no error displayed ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: G31 no error displayed ? (Read 10439 times)
Overloaded
4,923
on:
January 26, 2012, 08:06:36 AM »
G31 overshoot just stops.
No error message displayed.
Is it only an internal "error signalled" that stops the axis ?
"If the probe does not trip even after overshooting the programmed
point slightly, an error is signalled."
Russ
stirling
2,188
UK
Re: G31 no error displayed ?
Reply #1 on:
January 26, 2012, 08:45:41 AM »
Hi Russ
This was a major hindrance when I was writing my probing routines. I never did get a definitive answer but I couldn't find anywhere where an error was signalled. Maybe to a plugin - I don't know - but not to the user nor to CB that I could find. The other question I couldn't get an answer to was "why would G31 overshoot the programmed point anyway?".
Ian
Razordance Torch Height Control
Overloaded
4,923
Reply #2 on:
January 26, 2012, 09:07:30 AM »
Thanks Ian, I vaguely remember the overshoot discussion you mention.
I suppose the sequence not completing is an adequate "displayed error" in itself.
Was just curious.
Thanks again,
Russ
BR549
6,965
Reply #3 on:
January 26, 2012, 10:02:12 AM »
YEP I agree it was a BEACH that there was not an error signal. When running LONG probing routines it woul dbe NICE if the REcorded data SHOWED WHERE in the routine A PROBLEM existed. Even a simple parameter NUMBER like "9999" Where the 9999 means an overun. and it is VERY easy to spot in a data file.
X1.000 Y2.000 Z.000 A0.000
X9999 Y9999 Z9999 A9999
SOrry for the ramble but when you are probing intake ports on race engines and the routine runs for hundreds of thousands of probes these things become very important to know.
NOW back to the regularly scheduled program,
(;-)TP
Print
Pages:
1
Go Up
« previous
next »
