Hello Guest it is November 22, 2026, 11:09:35 PM
Author Topic: Stepper Motor HELP!!!!  (Read 9979 times)
micron
« on: December 28, 2006, 08:29:05 PM »
Hello, I'll keep this simple!
New to DYI CNC's
I have 3 Quicksilver Servo motors with Digital I/O Controllers,  I'm trying to set them up to work with MACH 3.  Any help is would be helpful
this is the link to the servo - http://www.qcontrol.com/support/datasheets/SM23%20DS%20r3.3.pdf
this is the link to the controller  http://www.qcontrol.com/saved/technical_docs/QCI-TD013%20Optical%20IO%20Module%20-%20OPTM%20and%20OPTO.pdf
These servos can either be connected via RS 232 or RS 485.
I presently have them connected as RS 232.
They all share the same TX and RX lines and are uniquely identified by a 2 didgit code. I cannot seem to figure out how to use these!
Stephane
Re: Stepper Motor HELP!!!!
« Reply #1 on: December 28, 2006, 10:07:35 PM »
Mach only runs step/direction drives, not serial comm.
