Hello Guest it is November 22, 2026, 02:08:11 PM
Author Topic: axis are stopping during cutting process?  (Read 26761 times)
« on: January 21, 2012, 02:06:08 PM »
Why my plasmatable axis are stopping for a moment during the cutting process when M15 (THC off) is read from G-code? If M15 is erased from G-code, cutting is continuous.
Re: axis are stopping during cutting process?
« Reply #1 on: January 21, 2012, 02:07:48 PM »
What is in the M15 macro?
« Reply #2 on: January 21, 2012, 02:23:37 PM »
I have no macro for M15
« Reply #3 on: January 21, 2012, 02:50:17 PM »
Then why do you have M15 in your code?
« Reply #4 on: January 23, 2012, 11:47:51 AM »
Whoops! M15 macro is: "Deactivatesignal(output2)"
« Reply #5 on: January 23, 2012, 01:03:54 PM »
What do you use OutPut2 for?
« Reply #6 on: January 24, 2012, 02:53:47 AM »
It swiches off automatic arc height control before leadout or in case it is better to cut in manual THC mode.
« Reply #7 on: January 24, 2012, 03:01:59 AM »
If the pause is only during the line with the macro then it is because Mach is reading the macro and acting on it so there will be a momentary pause, not much you can do about that.
You could try putting it on the same line as code but whether that would help I dont know, likely not.
« Reply #8 on: January 24, 2012, 03:21:33 AM »
I will try, thanks a lot!
« Reply #9 on: January 24, 2012, 04:24:02 AM »
It may be possible for you to instead utilise the M110/M10 commands instead.  It may not be working in the present download but should be soon in the development version.
