Hello Guest it is September 23, 2026, 02:01:10 AM
Author Topic: LCam Offset corners  (Read 24113 times)
Offline Ben
  •  79 79
LCam Offset corners
« on: January 16, 2012, 07:28:25 PM »
 I draw a box in TurboCad 18, explode it 8 times and save as a DXF.
In LCam I optimize it, select offset, a 1/4" mill, choose outside and a direction.
When I click Create Offset it offsets but rounds all the corners. If I choose inside it
does ok. What am I doing wrong? Ben
Re: LCam Offset corners
« Reply #1 on: January 16, 2012, 07:33:12 PM »
Hi Ben,
   The toolpath (centerline of the cutter) will be a radius around the corner leaving the actual part with a sharp corner.
Look at ot closely with the simulation.
Hope this is what you mean,
Russ
Offline Ben
  •  79 79
« Reply #2 on: January 16, 2012, 07:57:38 PM »
Thanks for the quick response. When I look at the G code it has a curve statement "G3" at each corner. Ben
« Reply #3 on: January 17, 2012, 05:32:17 AM »
Notice the sharp corner on the part and the tool path at the cutter centerline.
Offline Ben
  •  79 79
« Reply #4 on: January 17, 2012, 02:40:11 PM »
Thanks and also for the quick replies. I see the light. Ben
