Hello
Guest
it is
September 26, 2026, 11:07:03 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mach3 problem
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: mach3 problem (Read 20257 times)
komar1970
111
mach3 problem
on:
January 16, 2012, 02:23:31 PM »
if I load g-code to mach 3 and I press start button
This gives me a message
softlimit .worning..continue?
yes NO
what this message means thanks for reply
Logged
Carnoustie, Scotland
Re: mach3 problem
Reply #1 on:
January 16, 2012, 02:32:42 PM »
It means the code is going beyond the softlimits you have set. If this is a lathe then it will always throw that message even if the code will be within soft limits, it is on the list to be fixed but its not top priority.
Logged
komar1970
111
Re: mach3 problem
Reply #2 on:
January 16, 2012, 02:41:06 PM »
This is a milling machine and I had never this problem
Logged
Re: mach3 problem
Reply #3 on:
January 16, 2012, 02:45:00 PM »
Is your code maybe taking it without the softlimits you have set?
Do you possibly have a G90 and G28 on the same line?
Logged
komar1970
111
Re: mach3 problem
Reply #4 on:
January 16, 2012, 03:08:24 PM »
This problem can spoil my part? what I cutting out
Logged
Re: mach3 problem
Reply #5 on:
January 16, 2012, 03:11:15 PM »
Attach your code and your xml and I will have a look and see if I can find the problem.
Logged
komar1970
111
Re: mach3 problem
Reply #6 on:
January 16, 2012, 03:24:32 PM »
g-code
Last Edit: January 16, 2012, 03:29:07 PM by komar1970
Logged
Re: mach3 problem
Reply #7 on:
January 16, 2012, 03:35:36 PM »
I do not get a soft limit warning here so it has to be a setting you have in Mach, please attach your xml.
Logged
komar1970
111
Re: mach3 problem
Reply #8 on:
January 16, 2012, 03:56:50 PM »
file
Logged
Re: mach3 problem
Reply #9 on:
January 17, 2012, 01:59:38 AM »
You do not have softlimits set up as the settings are still default. You should turn off oft limits on the main screen or set the correct values for your table area from Config menu then Homing and limits.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
