Hello Guest it is November 11, 2026, 06:00:21 PM
Author Topic: DRO Question  (Read 51301 times)
DRO Question
« on: January 15, 2012, 12:19:08 PM »
Okay, I'm a newby and I'm creating my first screen.
I created a new screen for my Tool changer and I'm having an issue with a couple of DRO's.
When I add a DRO for Current Tool Number DRO - Code 24 it never actually displays the current tool, always Zero.
If I enter a number in there, it does update the Current Tool DRO on other pages, but mine still says Zero.
Also, I created another DRO and I'm trying display the value in the OEM DRO1200 but It always shows Zero as well.
I used the following:  OEM Code 12000
What am I doing wrong?
Richard
Re: DRO Question
« Reply #1 on: January 15, 2012, 12:36:39 PM »
Rather than using DRO 24, try using the System Function for Current Tool Number. Or. use OEM Code 824
1200, or 12000? Is 12000 a typo?
DRO1200 would be a user DRO, and you'd need to send data to it. What are you trying to do with it?
Re: DRO Question
« Reply #2 on: January 15, 2012, 12:42:21 PM »
Thanks,  1200,  I'm just trying to display the value stored in DRO1200.
Re: DRO Question
« Reply #3 on: January 15, 2012, 12:45:26 PM »
There is no value stored in DRO 1200 unless you put the value there. It's a User DRO, not a standard Mach3 DRO.
Re: DRO Question
« Reply #4 on: January 15, 2012, 12:51:05 PM »
I use it to store a value in from my M6Start Macro.
SetUserDRO (1200, NewTool)
Mach always starts up with Current Tool as 0,  The DRO1200 Stores the LastTool#
I use it in an init macro to set CurrentTool on startup.
Works very well however I want to be able to see it's value.
Richard
Re: DRO Question
« Reply #5 on: January 15, 2012, 12:57:24 PM »
I'm still not having any luck displaying the Current Tool.
In Screen Designer, I Add a DRO, the properties for the DRO are:
Function: Tool Number DRO
Code: 824
Format: %2D
If I go the Screen 1 and enter a tool number it's displayed properly in the DRO on Screen1 but the DRO on my new screen page always remains at Zero.
Re: DRO Question
« Reply #6 on: January 15, 2012, 01:18:24 PM »
And the two DRO's are the same?
Can you post the .set file?
Re: DRO Question
« Reply #7 on: January 15, 2012, 01:32:08 PM »
It's screen 11.  Don't laugh, I'm just playing and trying to get the hang of screens.
Re: DRO Question
« Reply #8 on: January 15, 2012, 01:40:50 PM »
The format is wrong. It should be %2.0f
Re: DRO Question
« Reply #9 on: January 15, 2012, 01:43:25 PM »
Ah, Thanks.  Let me try again.
