Hello Guest it is November 28, 2026, 07:09:07 AM
Author Topic: Checking for movement  (Read 10036 times)
« on: December 27, 2006, 11:58:01 AM »
I have an issue with the IsMoving() function. I'm trying to run it in a macro pump and everytime i use it i get an error with "cannot find recovery points, Solution too complex". I'm trying to use it in conjuntion with a door switch to pause the program. Code looks like this:
Moving = IsMoving()
DoorOpen = IsActive(Input4)
If DoorOpen and Moving then
      call DoOEMButton (1001)         'Set Safety Fault if door open and moving
      call DeActivateSignal (Output7)
      call SetUserLED (1024,1)
Else
End If
If i rem out the Moving = IsMoving(), then it will run, but does not stop when the door is opened, since moving = false. And i want this action to happen only if it is moving and the door is open, not if the door is open only. Any ideas?
Max
Re: Checking for movement
« Reply #1 on: December 27, 2006, 12:10:35 PM »
Hi Max,
    I know nothing of code, but thought this may intrest you. You could wire your switch to input one and check this box in general config. See pic.
