Hello Guest it is November 22, 2026, 02:27:36 PM
Author Topic: CNC Circle Pockets Coming Out Undersized  (Read 8830 times)
« on: January 13, 2012, 09:39:14 AM »
Hi All,
I've been milling a bunch of circular pockets and am finding them all to be
roughly .010" undersized in diameter (that's a lot!).
It doesn't matter whether it's a 2" diameter circle or a 0.5" diameter.
I'm using Mach3 and have compensated for backlash. In fact, the milled
circles are the same diameter vertically, horizontally and diagonally, which
I don't think would be possible if there were a backlash issue.
I've also used Mach3's axis calibration to verify that all axis are dead on
(ie. a move of 3.000" is exactly 3.000").
I've measured my .250" endmill and found it to be .247" in diameter. Rather
than setup the tool compensation table, I simply told my CAM program I was
using a .247" endmill.
The resulting g-code for the finish pass of a 2" diameter circle centered at x1, y1 is as follows:
G20 G40 G49 G54 G80 G90 G91.1
(LOAD .247 ENDMILL FINISH, PRESS Cycle Start)
T2 M6
M0
S2000 M3
G90 G54 X1.8765 Y1.
M8
G1 Z-.1 F1.
G17 G2 X1.8765 Y1. I-.8765 J0. F3.
G0 Z.1
M9
M5
Both my CAM program and Mach3 are using incremental mode for I and J.
I'm totally stumped, so any suggestions would be appreciated.
Ken
Re: CNC Circle Pockets Coming Out Undersized
« Reply #1 on: January 13, 2012, 05:29:33 PM »
Have you trammed the spindle in?  Is something flexing?
« Reply #2 on: January 13, 2012, 07:48:14 PM »
Hi Brett,
The mill is trammed but I now believe that this is a mechanical error. I have a number of tests to run and will report back when I figure out what's happening.
Ken
