Hello Guest it is October 20, 2026, 10:48:51 PM
Author Topic: OEM TRIG #1 - #15  (Read 8396 times)
OEM TRIG #1 - #15
« on: January 08, 2012, 03:22:27 PM »
HI
Just been watching some of the tutorial vids, it mentions these OEM TRIGS in the inputs tab, does this mean you could set up a control panel with up to 15 buttons, i am also guessing you would need a second parallel port to wire these up and to wire these up would it just be a single wire to the parallel port and one to the -VDC on the power supply on each button?
Chris
Re: OEM TRIG #1 - #15
« Reply #1 on: January 08, 2012, 03:53:35 PM »
Yes you can, you could also use something like the PoKeys to get the extra inputs if you wanted.
