Hello Guest it is November 22, 2026, 02:26:49 PM
Author Topic: Encoder distance  (Read 11298 times)
Encoder distance
« on: January 06, 2012, 09:00:09 PM »
How do I use the distance measured by an encoder instead of stepper position?  Also is it different on an encoder for absolute versus relative?
Thanks.  Eddy
Re: Encoder distance
« Reply #1 on: January 07, 2012, 04:23:38 AM »
Can you expand on your questions? Not sure what your asking.
« Reply #2 on: January 07, 2012, 09:55:12 AM »
I am working on a system that will drill holes on a ribbon wire.  The wire is continuous in length and comes off a roll.  I plan on using a take up roll to advance the ribbon.  As the take up roll gets more wire on it the diameter will change so I have an encoder wheel that can measure the distance the ribbon travels.  The machine is basically a 2 axis (X and Z).  I will drill a hole then move 0.2" drill again and repeat every 2" down the ribbon.  I am thinking that I might need to do this through brains or c code.  Unless there is a better way.  Thanks for the input.  Eddy
« Reply #3 on: January 07, 2012, 10:57:40 AM »
I would make a separate drive to advance the ribbon wire threw a pair of rollers. I would make the drive roller an axis then program the advancement in gcode. Pretty much Failsafe.
« Last Edit: January 07, 2012, 11:00:53 AM by BR549 »
