Hello Guest it is November 07, 2026, 08:22:17 PM
Author Topic: mach 3 /win 7  (Read 10254 times)
Offline dude1
  •  1,253 1,253
mach 3 /win 7
« on: December 30, 2011, 05:52:30 PM »
is there going to be a mach3 put out that will run under win 7 64 bit as about to start bulding a new machine would like to run it on a new computer ie win 7
Offline allyd
  •  24 24
  • Aussie Aussie Aussie
Re: mach 3 /win 7
« Reply #1 on: December 30, 2011, 10:35:18 PM »
It runs perfectly under win 7 64 but not through the P-port, I'm running a Smooth stepper.
Offline dude1
  •  1,253 1,253
Re: mach 3 /win 7
« Reply #2 on: December 31, 2011, 12:05:54 AM »
what im getting at is when i do some thing with cut2d and send it to mach3 it can not find it ie mach3, or if i find a gcode on the net that i wont to do but its in inch as i run metric only with win xp i lode it to mach3 then open lazey cam and pull it through with win 7 i can not do it. these are things i would like to work, as going from inside computer to cnc computer to check if things are going to work is a pain. in nz you cant get xp anymore only second hand computers what are some else junk.
Re: mach 3 /win 7
« Reply #3 on: April 28, 2012, 07:47:11 PM »
well a smooth stepper costs $150 I can buy a used pc for $50 with win xp  then problem solved
