Hello Guest it is September 26, 2026, 06:44:41 AM
Author Topic: Spindle water cooling system 2.2KW  (Read 39679 times)
« on: December 30, 2011, 07:26:33 AM »
I wanna show my solution for the water spindle, it's working so good.
http://youtu.be/Qy_ja34B8ng
At 35 degrees the fans and LED's switch on, at 33.9 off.
I couldn't find so many information about this so I wanna share my solution.
Juan
  •  9,374 9,374
Re: Spindle water cooling system 2.2KW
« Reply #1 on: December 30, 2011, 10:16:03 AM »
Great idea Juan. Do you have any information on the temperature controller you are using ??
« Reply #3 on: December 30, 2011, 08:09:20 PM »
A little bit more of information.
The cooling kit is:
XSPC Rasa 750 RS360
The fluid is:
Feser One Non Conductive. You can choose many different colors
http://www.youtube.com/watch?v=9wdQmfcNkgw&feature=youtube_gdata_player
Juan
  •  9,374 9,374
« Reply #4 on: December 31, 2011, 04:10:01 AM »
Hi Juan,
Thanks for the info, that is most interesting.
(I don't think I would want to put the 'Feser One Non Conductive' to a real electrical test though  ;D )
« Reply #5 on: December 31, 2011, 10:20:27 AM »
Yes Tweakie, With a 12V DC fan is easy but with a 220V AC spindle we should see what happens, but nothing good for sure. Hahaha!
Juan
  •  9,374 9,374
« Reply #6 on: December 31, 2011, 11:34:20 AM »
I don't think you will have any problems at 220 Volts whether the water is marginally conductive or not.
I use a similar 3 fan radiator, circulating pump, flow sensor, silicone tubing etc. with distilled water and 30% antifreeze for cooling my laser tube which runs at 16,000 Volts. There are no problems (but I would not want to stick my finger, or anything else, into the water when it is running).  ;D ;D
« Reply #7 on: May 21, 2015, 06:58:01 AM »
Can I use 50/50 antifreeze/coolant from autozone? Straight out of the bottle? Or should I mix it?
