Hello Guest it is October 23, 2026, 12:04:37 PM
Author Topic: CNC Dictionary  (Read 59146 times)
Re: CNC Dictionary
« Reply #30 on: January 02, 2012, 11:25:04 AM »
Spreadsheet with links is ok but what happens if the linked content is removed?
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: CNC Dictionary
« Reply #31 on: January 02, 2012, 01:00:44 PM »
Maybe this could be the impetus for an attempt at rationalising Mach documentation. Currently we have stuff all over the place:
Mach videos - a link under the support item above
Mach documentation - a link under the support item above
Mach Wiki - a link under the support item above
Members docs - a sub forum here
Downloads/tutorials and downloads/documents - two sub forums here
http://groups.yahoo.com/group/mach1mach2cnc/files/ a kind of allsorts archive
and probably loads of others
How about ONE place for all - maybe under the Wiki
Just my two penneth
Ian
Re: CNC Dictionary
« Reply #32 on: January 02, 2012, 01:31:29 PM »
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
Re: CNC Dictionary
« Reply #33 on: January 02, 2012, 04:09:36 PM »
Hood I think a spreadsheet with links as suggested, I think by Rich, is a good idea too. If we make a copy of the info in the spreadsheet and attribute it with a URL, then if the website disappears it wont matter. The software for viewing and editing spreadsheets is available for free, if you use "open office" or LibreOffice,  among others. I will create the spreadsheet using LibreOffice - feel free to try the dictionary spreadsheet out with different types of spreadsheet programs.
David
Re: CNC Dictionary
« Reply #34 on: January 03, 2012, 01:42:43 PM »
what is a charge pump?
regards
Re: CNC Dictionary
« Reply #35 on: January 03, 2012, 03:35:33 PM »
Visa power shopper on Boxing day sales!!
Or more correctly a means of Mach indicating when booting, shutting down or PC failure, can be used for servo or E-stop shut down.
Equivalent to the common Watch-Dog Timer used in processor based control systems.
Nosmo.
Re: CNC Dictionary
« Reply #36 on: January 03, 2012, 06:11:09 PM »
Probably best to compile the dictionary and have one group to control the PDF. That has worked well in the past.
PDFs print very well as a hardcopy manual.
BEST to NOT use the charge pump as an estop as MACH3 can lock up tight and the change pump still runs fine. The original purpose of the CP was to prevent the tickling of the LPT ports during bootup.
Just a thought, (;-) TP
« Last Edit: January 03, 2012, 06:13:50 PM by BR549 »
Re: CNC Dictionary
« Reply #37 on: January 03, 2012, 07:29:23 PM »
I realize that was the original intent, but personally I want to shut everything down if something has happened to the PC or the program, I look at it as the next best thing to a watch dog if AND'ed  in the E-stop string.
Nosmo.
Re: CNC Dictionary
« Reply #38 on: December 17, 2014, 09:11:38 PM »
You guys are killing me.  I opened every one of those files hoping to find a real dictionary.  Not.
Since the days of this thread, Google docs if fee to all... or am I about to discover something in the next thread I search for this Holy Grail?
  •  9,374 9,374
Re: CNC Dictionary
« Reply #39 on: December 18, 2014, 12:50:11 AM »
Your not alone OB I've been using Mach3 for over 10 years now and I still don't know the half of it.   ;D ;D
