Hello Guest it is October 23, 2026, 12:05:03 PM
Author Topic: CNC Dictionary  (Read 59147 times)
Offline Vogavt
  •  260 260
Re: CNC Dictionary
« Reply #20 on: December 31, 2011, 10:01:45 AM »
Acceleration
Active Lo
Active Hi
Active Plane
Arc Motion
Axes (define X, Y, Z, A, B & C in planes)
Backlash
Ballnut
Block
Canned Cycles
Charge Pump
Chip load
Clamping (see Work Holding)
Cutter Compensation
CV
Debounce
Digitizing Probe
Distance Mode
DRO's (Digital Readouts)
Dwell
Edge Finding
Encoders
Endmills
EStop
Feedrate
GCode
Guard Interlocks
Home Swithes
Initialization String
Interpolation
Jogging
Leadscrew
Limit Switches
Machine Zero
Macro
MDI (Manual Data Input)
ModBus
Modal Groups
Motor Tuning
MPG
Offsets
PLC
PWM
Rotary Table
Servos
Slaved Axis
Software Limits
Spindle
Step and Direction
Steppers
Tangential Control
THC
Toolpath
VBScript
Velocity
VFD
Work Holding Devices
Work Offset
Should be a good start for anyone wanting to take on the daunting task. I would but I can't at the moment or even for the next few days.
Vogavt
Re: CNC Dictionary
« Reply #21 on: January 01, 2012, 07:16:35 AM »
 Vogavt,
I would but
We can waite..... ;)
Wish you luck on the dictionary.
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
Re: CNC Dictionary
« Reply #22 on: January 01, 2012, 03:51:22 PM »
Ok thanks Vodavt, it looks like it's time to put my money where my mouth is, or at least where my typing finger is. I'm not too sure about the copyright on things like pictures - does anyone out there know?
 Anyway, to be safe I've left the photos out pending copyright clarification. I also wonder how much content we can use from sources like Wikipedia? I wonder as well if we have to use original text? It would certainly be a lot easier to cut and paste from original sources on the net.
Eagerly awaiting your replies
David
Offline DMBGO
  •  201 201
Re: CNC Dictionary
« Reply #23 on: January 01, 2012, 03:58:49 PM »
I forgot to mention that the dictionary needs to be a collaborative effort, although, reading Rich's post seems to indicate that this is the general idea. Is it possible to have a shared location for the file? Although I will be happy to update the document in the mean time.
Also do we need to acknowledge contributors? I personally think not, since they are acknowledged on the thread anyway.
« Last Edit: January 01, 2012, 04:01:05 PM by DMBGO »
David
Re: CNC Dictionary
« Reply #24 on: January 01, 2012, 04:02:44 PM »
Dave,
Feel free to use the 19 pages for Arc Motion in the write up you will find in Members Docs.
For some items a simple definition just won't cut it or be of value without the understanding.
Offline DMBGO
  •  201 201
Re: CNC Dictionary
« Reply #25 on: January 01, 2012, 04:51:30 PM »
Hi Rich, I'm afraid I don’t know where that which you refer to is?
"Dave,
Feel free to use the 19 pages for Arc Motion in the write up you will find in Members Docs."
David
Re: CNC Dictionary
« Reply #26 on: January 01, 2012, 04:57:50 PM »
Dave,
Not sure about the copyright stuff but agreed it needs to be a collaborative effort.  Anyone wanting to contribute can download the last, edit and repost with a higher revision number. I think the curretn format is good.  If it grows we can eventually get a more permanant spot for it.  We could also make this a sticky topic in the members docs area but visitors cant see that board.
Re: CNC Dictionary
« Reply #27 on: January 01, 2012, 05:01:27 PM »
Here is what Rich was talking about.
http://www.machsupport.com/forum/index.php/topic,11932.0.html
Re: CNC Dictionary
« Reply #28 on: January 02, 2012, 05:22:13 AM »
Have you considered doing a spread sheet for each of the terms and then providing a link to good sources of information on the subject?
Offline Vogavt
  •  260 260
Re: CNC Dictionary
« Reply #29 on: January 02, 2012, 11:02:34 AM »
I thought about a spreadsheet too, but wasn't certain everyone would have or need that type of software.
Most folks have at the minimum a word processor of sorts and hyperlinks can be created there.
Great idea on point a link. I would go for a brief description then have a link called "More Info".
The downside is that if you wanted to print the document you'd lose the ability to reference external material.
My two pennies...
