Hello Guest it is September 18, 2026, 10:15:27 AM
Author Topic: USB MPG problem  (Read 10154 times)
USB MPG problem
« on: December 28, 2011, 09:09:41 AM »
Looking for help with China made Mach only pendant. Uses USB and Comm ports to connect. I believe I have followed the instructions to install the pendant. All functions work as they should with the exception being axis selection. I have to select the axis I want the MPG to  operated on Mach screen. Mach does not seem to recognize the select buttons on the pendant. Any ideas ? Thanks
Scott
Re: USB MPG problem
« Reply #1 on: December 30, 2011, 08:43:20 AM »
Found problem to be that I did not have the Macro pump installed.
Re: USB MPG problem
« Reply #2 on: April 02, 2012, 02:03:22 PM »
Is this a diycnc mpg. If so I have one also and I am trying to change the step settings so I can step down to 0.001" .
Right now the smallest increment is 0.01 " Do you know how to change the setting s for this .
Thanks Rick
