Hello Guest it is November 23, 2026, 03:18:53 AM
Author Topic: problem with pci express  (Read 28171 times)
Re: problem with pci express
« Reply #10 on: December 25, 2011, 11:29:11 PM »
yes i must change it but im not sure i can find it in my city
« Reply #11 on: December 26, 2011, 02:48:34 AM »
Might be worth looking at a SmoothStepper instead, depending on the price of these cards.
« Reply #12 on: December 28, 2011, 11:48:27 AM »
sorry but what is smooth stepper?
and does it work with laptop?
« Last Edit: December 28, 2011, 11:50:58 AM by shs_micro2 »
« Reply #13 on: December 28, 2011, 01:14:14 PM »
Smoothstepper is an external motion controller that connects to the computer via USB and communicates with Mach via a plugin. There will also shortly be an Ethernet version available. The SmoothStepper is I think around about $150.
« Reply #14 on: December 29, 2011, 12:57:11 PM »
it means the smoothstepper is better than parallel convertor(if the cost be near)
« Reply #15 on: December 29, 2011, 01:05:55 PM »
The SS has many advantages over the parallel port but also a few disavantages, the fact is the parallel port supports all functions of Mach and the SS as with other external controllers dont. Most are supported by the SS but a few like Torch Height Control are not. The SS is a very clean pulse and  it can pulse up to 4MHz which is a big advantage if using servos.
« Reply #16 on: January 01, 2012, 01:54:15 PM »
thanx for your usefull help
im looking for an express card and i will find it
because if  want to use other app i want i can
« Reply #17 on: January 14, 2012, 02:28:21 AM »
hello
i buy the express cart and it works great(it make a realy lpt port for laptop)
it is about 35$
