Hello Guest it is November 13, 2026, 10:34:05 PM
Author Topic: User Defined Function  (Read 7505 times)
Offline 10k
  •  13 13
« on: December 23, 2011, 08:51:58 AM »
Is there a way to create user defined functions that are available globally?
In the screen designer, I have defined several buttons that execute VB code.  The functions are similar, but not identical.  I have a VB function that's defined in a large section of code.  I'd prefer not to include the code that defines the function in each of the calling buttons.  If I do, I have to keep editing every instance when I make a change.  What I'd like to do is:
     Button 1-10 - just a few lines of code that call function using different parameters.
     Large chunk of code defining function - located somewhere else.
I need to pass parameters to the function, and receive return parameters from the function.  The function needs to complete execution before returning control to the calling VB code.
Is there a way to do this?  I've searched the forum and so far it appears that you can't do this.
Thanks.
Re: User Defined Function
« Reply #1 on: December 23, 2011, 09:08:25 AM »
