Hello Guest it is November 13, 2026, 12:18:23 PM
Author Topic: after the crash - episode 2  (Read 9539 times)
« on: December 22, 2011, 02:45:34 AM »
I am not going to reinstall because I am scared of loosing the calibrations
Can I re install and not have to recalibrate everythinh again
regards fred evans
  •  9,377 9,377
Re: after the crash - episode 2
« Reply #1 on: December 22, 2011, 07:28:16 AM »
Hi Fred,
All of your previous set-up will be stored in the .xml file (named as the profile you are using .xml) and located in you Mach3 folder. Copy this file, save it somewhere safe (memory stick is good), then use it to over - right the new .xml file after the re-install. It is also wise to keep a copy of your license file and screen set, just in case everything gets deleted.
