Hello Guest it is November 13, 2026, 10:25:34 PM
Author Topic: Cypress Enable dialog error - Only on XP  (Read 11994 times)
« on: December 21, 2011, 08:26:02 PM »
This is an odd problem.  In the code below, I get the error message "Error line 64 - Internal Error - <Dialog>".  Line 64 is.....
button = Dialog( Dlg1 )
See code segment below.  I developed a really cool screenset using a number of these dialog functions.  I developed it on my laptop running Win7 and it all works perfectly.  When I run the same code on XP, I get the above error.
Has anyone seen this before?  Is there something from microsoft that I need to install to make the Dialog function work in XP?
Thanks.
Begin Dialog UserDialog1 20,40,240,110,"Enter Circle Parameters", .enable
  OKButton 190,20,40,14
  CancelButton 190,40,40,14
  text 10,10,40,10, "Width"
  text 10,25,40,10, "Height"
  text 10,40,40,10, "Kerf Width"
  text 10,55,40,10, "Feed Rate"
  text 10,70,40,10, "Num Points"
  text 10,85,40,10, "Inner Offset"
  textBox 50,10,30,10, x1,.width
  textBox 50,25,30,10, x2,.height
  textBox 50,40,30,10, x3,.kerf
  textBox 50,55,30,10, x4,.feed
  textBox 50,70,30,10, x5,.points
  textBox 50,85,30,10, x6,.offset
  GroupBox 95,10,80,45, "Kerf Compensation", .groupBox1
  OptionGroup .grp1
    OptionButton 105,20,54,10,"None"
    OptionButton 105,30,54,10,"Inside"
    OptionButton 105,40,54,10,"Outside"
End Dialog
Dim Dlg1 As UserDialog1
Dlg1.width = settings(2)
Dlg1.height = settings(3)
Dlg1.kerf = settings(0)
Dlg1.feed = settings(1)
Dlg1.grp1 = settings(12)
Dlg1.points = settings(13)
Dlg1.offset = settings(14)
opt1 = Dlg1.grp1
nWidth = Dlg1.width
nHeight = Dlg1.height
kerf = Dlg1.kerf
feedRt = dlg1.feed
numSides = Dlg1.points
offset = Dlg1.offset
If button = -1 Then
Re: Cypress Enable dialog error - Only on XP
« Reply #1 on: December 22, 2011, 09:32:24 AM »
I get the same error running in XP Mode on Windows 7, but it does work on just Windows 7 after removing the "... = settings()" function calls and the "If Button = -1 then" lines.... Error is then on line 26, but it's referring to the same thing. Funy that on Win7 it works OK though.
Nothing, AFAIK, needs to be installed to make this work - the function should be supplied by Enable...
I'm sick today, but if I get some time where I'm feeling OK I will go ever the code and look for errors. I just can't concentrate right now...
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: December 22, 2011, 10:23:27 AM »
The cypress man is pretty cr@p but I reckon the syntax of your textboxes is incorrect and should be:
TextBox X, Y, DX, DY, .Field$[, Options]
which means (if I understand what you're trying to do):
textBox 50,10,30,10, .width,0
and then later:
Certainly if I mod your code as per...
Code: [Select]
  textBox 50,25,30,10, .height,0
  textBox 50,40,30,10, .kerfWidth,0
  textBox 50,55,30,10, .feedrate,0
  textBox 50,70,30,10, .numPoints,0
  textBox 50,85,30,10, .InnerOffset,0
  OptionGroup .grp1
End Dialog
Dlg1.width = 1000
Dlg1.height = 500
Dlg1.kerfWidth = 1
Dlg1.feedrate = 6000
Dlg1.numPoints = 50
Dlg1.innerOffset = 50
then I get this under XP (see attached pic) - is this what you intended?
Not sure why it worked under W7 because I reckon it shouldn't have. Local conditions of course may vary.
Ian
« Reply #3 on: December 22, 2011, 05:11:32 PM »
That did the trick.  Thanks for the tip.   Weird how this error only happens in XP.  It's usually the other way around.  XP is usually more stable.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #4 on: December 23, 2011, 03:14:43 AM »
I think that's perhaps the point. As well as perhaps being more stable XP seems less forgiving of incorrect syntax. Your code SHOULD have failed on W7 and the fact that it didn't is W7's shortcoming NOT XP's.
« Reply #5 on: December 23, 2011, 08:05:19 AM »
I see your point...
