Hello Guest it is October 23, 2026, 06:17:49 PM
Author Topic: gcode for "home"  (Read 13902 times)
gcode for "home"
« on: December 19, 2011, 04:28:58 AM »
if there is a gcode for the command "go to home" could someone please give it to me
At the same time please tell me if there is a hoykey for the same purpose??
best regards and thanks
Fred
think of the trees-- use both sides of the computer paper
Re: gcode for "home"
« Reply #1 on: December 19, 2011, 04:49:16 AM »
Click the "GCODE" button near the reset button on the screen for a list of gcodes. Also may want to have a look in the manual.
at G28.
« Reply #2 on: December 19, 2011, 07:52:11 AM »
WHich HOME do you want.
There is G28 that sends the machine to what is defined in config  OR
There is G30 which sends it to the true home position as defined by the home switches OR
There is G0X0Y0 which sends it to the Point of origin (HOME) of the work corrds.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: December 19, 2011, 11:06:06 AM »
Or you can search for home with G28.1 X0 Y0 Z0
Graham
« Reply #4 on: January 05, 2012, 09:28:33 AM »
Thanks tp - you said:-
Yes I got this one -- If I code G0 it rapid feeds to the home position I set on the manual screen
 Are these home switches hardware that have  been installed on ther machine ? If so
I do not have home switches
Not sure what this means?? Is this the y=0 and the Z=0 referring to the axis positions
as they are defined on the axis position dro group?
Thanks graham,
you said:-
Graham
Not sure what you mean by :search for home"  Please elaborate
Also please explain the decimal point that is part of the word "G28.1" ?
Offline Hal
  •  60 60
« Reply #5 on: January 05, 2012, 04:40:01 PM »
If you are using Fixture Offsets (G54 G55 ...) try
G53 Z0.
G53 Y0.
G53 X0.
This sends my machine home and to my manual tool change and part changing position.
