Hello Guest it is November 13, 2026, 12:59:05 PM
Author Topic: Spindle moving slowly from right to left  (Read 12588 times)
« on: December 18, 2011, 01:24:45 AM »
Hi everybody, i am new in cnc machine, when l turn on spindle motor from control box without loading any G-Code, my spindle bits will move slowly from right to left. Can anyone tell me what actually happening here. I afraid that it will cause different end results if l load my G-Code. Thank you.
  •  9,377 9,377
Re: Spindle moving slowly from right to left
« Reply #1 on: December 18, 2011, 03:37:47 AM »
Hi Ben,
Could well be electrical noise. Are you using a VFD with your spindle motor ??
« Reply #2 on: December 18, 2011, 03:58:36 AM »
Exactly, mine is 220v cnc machine with 800W spindle and 1.5KW VFD, please help me, l am confused now.
  •  9,377 9,377
« Reply #3 on: December 18, 2011, 04:28:52 AM »
Hi Ben,
VFD's are notorious for producing electrical noise.
Check that you have no 'earth loops' and that your VFD is only earthed at one point.
Re-route your spindle cable away from any signal cables.
Check that you have no 'GND loops' in your wiring layout.
Use shielded cable for your limit and estop switches and only connect the screen at the controller end.
Just a few things to try,
« Reply #4 on: December 29, 2011, 04:03:55 AM »
Hi Tweakie, sorry for late reply. The problem that l had is due to "rubbish pulse in my cnc working environment", thank you Tweakie for helping me to solve my problems, you are awesome  ;)
  •  9,377 9,377
« Reply #5 on: December 29, 2011, 04:30:25 AM »
Hi Ben,
I am really pleased that you found the problem and it is working OK.  ;D
