Hello Guest it is November 22, 2026, 02:27:43 PM
Author Topic: Need Help  (Read 16492 times)
Need Help
« on: December 16, 2011, 08:31:28 PM »
Hello new here. Trying to use the CAD drawing below and get it into mach 3. Its a boring operation and mach and lazy cam do not read them properly and i am having trouble generating G-code that ends up looking like this when it finally gets to mach 3. The red are my roughing cuts to remove materiel the yellow is my roughing of my profile and the green is my final pass. All help is much appreciated.
Re: Need Help
« Reply #1 on: December 17, 2011, 06:16:22 AM »
Post the cad drawing.
Re: Need Help
« Reply #2 on: December 17, 2011, 11:15:04 AM »
Here is that CAD file. Again very new to all this so thanks for your help.
Re: Need Help
« Reply #3 on: December 17, 2011, 11:28:19 AM »
Sorry, need a dxf or save for ACAD v 2007 or lower.
Re: Need Help
« Reply #4 on: December 17, 2011, 11:44:23 AM »
Sorry about that. Here is a DXF 2007
Re: Need Help
« Reply #5 on: December 17, 2011, 12:05:10 PM »
When you say a boring operation are you meaning using the LC's lathe module?
or
Do you really mean it's a milling operation?
Re: Need Help
« Reply #6 on: December 17, 2011, 12:10:09 PM »
It a lathe boring operation. I forgot to mention that i am using mach3turn. Not sure if this helps i hope so.
Re: Need Help
« Reply #7 on: December 17, 2011, 12:30:15 PM »
I haven't fooled with Lazycam's lathe module in a long time and frankly it can be a challenge since the tool definitions were never completed.
First thing to do is have a read of the manual for Lazycam which can be found in Members Doc's.  See Tutorial #5 for lathe specifics and redraw your drawing per the tutorial. Make darn sure you simulate the code in Mach Turn and pay attention to possible bad XZ moves in the posted code.
Wish ya luck,
Re: Need Help
« Reply #8 on: December 17, 2011, 12:32:43 PM »
Thanks for all the help i will see what i can figure out.
Re: Need Help
« Reply #9 on: December 17, 2011, 12:35:10 PM »
BTW, You need the pro license to use the lathe module.
