Hello Guest it is November 13, 2026, 12:07:45 PM
Author Topic: NOTEBOOK PARALELL PORT CARD  (Read 12181 times)
beetlesports
« on: December 25, 2006, 12:42:55 PM »
HI FOLKS,
 COULD THIS BE A SOLUTION TO USE MACH3  USING PARALELL PORT ON A MODERN LAPTOP?
  http://www.transdigital.net/info.htm
Re: NOTEBOOK PARALELL PORT CARD
« Reply #1 on: December 25, 2006, 02:19:55 PM »
You are better off to go with the NCPOd from http://ncpod.oemtech.com/  This will make it so you can run from a USB port :)
www.newfangledsolutions.com
www.machsupport.com
Offline Raca
  •  10 10
« Reply #2 on: December 26, 2006, 10:33:48 AM »
Yes this is something that still work on my system. I didn't try Bryan's system ,but you can work for shure  with Transnet digital PC MCI to parallel card. Parallel port communication is something that is mather of the past but Brian's sugestion will work whit  new Mach realises.
