Hello Guest it is November 13, 2026, 09:39:37 AM
Author Topic: E-Stop from high pitch?  (Read 10922 times)
« on: December 12, 2011, 09:12:04 AM »
When I try to cut with a 1/4" bit it makes a loud high pitch sound and mach goes into e-stop.I can hit the reset and every thing works fine again until the bit touches the wood to cut.I just cut with a 1/2" bit with no problem. any thoughts??
  •  9,377 9,377
Re: E-Stop from high pitch?
« Reply #1 on: December 12, 2011, 09:44:08 AM »
Could be the switch contacts being affected by vibration.
« Reply #2 on: December 12, 2011, 09:57:44 AM »
Thanks, Would the best way to check this be to put jumpers on the limit and estop switches ? They are all normally closed switches.
  •  9,377 9,377
« Reply #3 on: December 12, 2011, 10:05:49 AM »
Yes, perhaps that would be the best way.
It is probably only just one switch that is causing the problem or possibly a loose connection to one switch.
« Reply #4 on: December 12, 2011, 10:40:46 AM »
Thanks for your help! I went ahead and disabled all my limits in Mach3 conf. and was able to finish my cuts.Now I will go back and narrow down my problem. I love your quote,how appropriate for us that have built a CNC machine. Thanks again, Tommy
