Hello Guest it is October 04, 2026, 02:19:28 PM
Author Topic: Mach3 can't jog  (Read 21987 times)
Mach3 can't jog
« on: December 25, 2006, 10:58:04 AM »
Ok, I decided to upgrade to mach3 from mach1 which is on my Shoptask machine.  I can't seem to jog around to begin using it.  I hit reset and the jog on/off button but still no go.  Mach1 works just fine.  What am I missing?
The reason I am upgrading is I purchased a 48"x48" router this summer using Flashcut system.  Works pretty well.  But I upgraded my controller to a Camtronics 4axis system and I thinkg mach3 will do a better job with this.  Since I already use mach1 on my shoptask, I thought I might as well learn mach3 for both machines and get rid of the Flashcut.
« Last Edit: December 25, 2006, 11:06:50 AM by lockeyone »
If you want to kill time, why not work it to death!
Re: Mach3 can't jog
« Reply #1 on: December 25, 2006, 11:05:15 AM »
Can you post your xml?
Re: Mach3 can't jog
« Reply #2 on: December 25, 2006, 11:08:41 AM »
ok, this is one camtronics sent me for the shoptask.
Re: Mach3 can't jog
« Reply #3 on: December 25, 2006, 11:16:49 AM »
Is this the Mach 3 xml or Mach1 xml
Re: Mach3 can't jog
« Reply #4 on: December 25, 2006, 11:36:21 AM »
Try enabeling your motor outputs.
Re: Mach3 can't jog
« Reply #5 on: December 25, 2006, 11:48:51 AM »
Cool, now were cookin.  I even played with setting my jog buttons.  Thanks for working on xmas day!
« Last Edit: December 25, 2006, 11:58:14 AM by lockeyone »
Re: Mach3 can't jog
« Reply #6 on: December 25, 2006, 12:27:44 PM »
Re: Mach3 can't jog
« Reply #7 on: December 25, 2006, 05:53:08 PM »
Ok, was playing with it some more.  I can't figure out how to reverse the motors.  When I jog all motors (x,y,z) all move opposite of what I should have.  Another thing is how do I set the jog rate?   I see the percentage dro in the mpg mode window.  Any way to set up a default speed?
Re: Mach3 can't jog
« Reply #8 on: December 25, 2006, 06:13:30 PM »
Jog rate is what your motor tuning is, ie the max you have tuned is your jog speed. If you want slower then set the percentage down to whatever you want and it will stay that way.
 To reverse the motors you can do it several ways, one way is to change the "Dir Low active" to the opposite that you have now.
