Hello Guest it is November 22, 2026, 10:03:50 AM
Author Topic: Mach3, Arduino, Modbus and MPG  (Read 164735 times)
Re: Mach3, Arduino, Modbus and MPG
« Reply #20 on: February 15, 2013, 07:01:25 AM »
so, any word, did you get it working?
« Reply #21 on: February 15, 2013, 08:51:09 AM »
Haven't tried it yet. Maybe next week. Another out of town visit is on schedule.
« Reply #22 on: February 25, 2013, 12:20:14 PM »
Hi guys
I think the problem with arduino mpg is the same as when connected to some BOB, the debouncing, Mach3 has to adjust it but does not properly with the mpg, this requires putting buffer and / or convert step and direction signals (see attached)
« Reply #23 on: March 16, 2013, 09:47:59 AM »
Zafar
I am a newbie and i am working with your source.
I have a problem. I want to set pin default state is low but I don't know how (Sorry, I'm just beginer with code).
For example, when I connect pin 2 to gnd, the rx is "01 04 02 DF FF" but i need rx is "01 04 02 20 00"
How can I config it ? Please help me!
Phuoc
« Reply #24 on: March 16, 2013, 03:29:03 PM »
(1) Go to the Arduino website.
(2) Study the examples in the "Learning section."
(3) Learn operation procedure and functions for I/O with an Arduino board.
(4) Write some simple sketches to verify the many kinds of functions in the Arduion IDE.
(5) Test a basic I/O on the ModBus sketch, such as creating an input from a pushbutton, and a brain to cause a Mach3 action, or copy the example posted by Zafar using a potentiometer.
« Reply #25 on: September 18, 2013, 07:09:57 AM »
Zafar,
   I have a cheezy, Arduino here, and there is a "Timer" style kinda function you can call.
The resolution of that time would need to be in the ms granularity.
In any case, the "Tick Counter" in the arduino would need to at the minimum be MUCH faster,
than the 10hrz update loop.
If it where me, I would then send that Tick Value across the modbus in the standard 16 bit register,
I would then map that register address (in the modbus config in mach), to the "Tick Count" termination object.
Scott
Scott,
I've programmed the TickCount function in Arduino too. I am counting the pulses produced during the last 50 ms, multiply it by 20 to get the pulses per second and then pass it over to Mach through modbus. But still get the same result :(. Almost 1 second's delay between MPG movement and machine axes response. The same thing I got when I was not using the MPG TickCount in Mach brains.
Zafar
« Reply #26 on: September 06, 2014, 10:34:32 PM »
Hello Zafar:
I have not yet connected an MPG through the ModBus, but have all the I/O pins on the Arduino Mega, pin #2 through #53 digital, and all of the Analog inputs tested, working just fine.
mrprecise44,
Care to share your sketch of the Mega ? Im new to the arduino and this would help me out tremendously with my mega.
« Reply #27 on: September 07, 2014, 07:35:54 AM »
I'll be busy all this week. Maybe this weekend, I'll fish out the arduino code and post it here.
Zafar
« Reply #28 on: January 18, 2017, 04:49:47 PM »
Maybe I solved the problem:
I had a delay of something about 0.5 and 1.5 seconds and tried everything, till i found a "Serial.print("*********");" in my code... After deleting it, everything worked out perfect! I hope I can help someone with that in the future!
Cheers!
« Reply #29 on: March 11, 2019, 02:41:14 PM »
Hi there,
I know that this topic is old but can you manage to make Mach3 to "talk" with Arduino?
If yes.... How manage to send out to Arduino the signals for moving axes? (xstep, xdir.....)
And how can be adresed bit's upper than 15?
In one word.... Can you share with us what you done?
Thank's in advance from Romania.
